Ricor Intiminator Questions - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 52 (permalink) Old 08-24-2010, 05:56 PM Thread Starter
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
Like so many others on this site, I installed a set of Ricor Intiminators last year. Generally positive results over bumpy, patched asphalt, though like some others, my front forks now trend to hunt up and down slightly on very smooth roads. Distracting, because it feels like a slightly out-of-balance wheel. Brian from Ricor suggested drilling a bleed hole .050" directly through the center of the bolt in the Intiminator.
However, someone else on the forum made a good point. Not all the Intiminator equipped bikes are exhibiting the hunting problem.
I was going to use the survey format for this, but couldn't seem to find it (??)
Anyway, here's the questions. I'd really appreciate seeing this info from anyone who has experience with the Ricors on their Bonnies/Thrux/Scram. I don't want to drill bleed holes in the Intiminators if there's another solution.
1. Does your bike exhibit the hunting symptom on smooth pavement? (Y/N)
2. Do you run the factory recommended fork oil level? (Y/N) If not, elaborate.
3. Do you run the Ricor recommended fork oil weight (Amsoil 5w)? (Y/N) If not, elaborate
4. Do you run the original equipment fork spring with the Intiminator (Y/N) If not, elaborate
5. You ride a Bonnie/Thruxton/Scrambler (?)
Thanks,
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #2 of 52 (permalink) Old 08-24-2010, 06:12 PM
Main Motorcycle: Triumph Street Triple.
Other Motorcycle: Aprilia RS125
Thumbs up Ricor Intiminators...
Thanks,
Bob
I've been on the Intiminators since they became available for Triumph.
My Bonneville exhibits no "hunting" or wobble at all on smooth or rough road surfaces.
I run Shell 5 weight fork oil.
Oil is 120mm from top of fork tube with Intiminator in fork and no spring, fully compressed.
The spring is original equipment with 1/2" cut off the spacer.
My fork feels stiffer than standard, doesn't compress as easily but I have the bike set up for fast cornering, with the rear end shocks [IKON's] preload set on position 3 with the damping on 3 so the front and rear are in perfect tune.
The suspension feels quite firm overall and I can push the bike very hard on the back roads. The Avon Roadrider tires are one size bigger in front and rear on standard rims. [140-70-17 rear and 120-70-17 front].
No steering damper. NH rearsets. The bigger tire on the front is really magic.
Anything else you need to know?
S.
2010 Street Triple. Black.
"Just because you're breathing, doesn't mean you're alive"
Sp00ky is offline
post #3 of 52 (permalink) Old 08-24-2010, 06:22 PM
Main Motorcycle: 2008 Thrux
NorthernThrux's Avatar
Other Motorcycle: 2010 Speed Triple
Only think I'm hunting for with Ricor is good customer service !
No.
I run 134 mm from the top of the compressed fork.
Bel-Ray 5 W
Racetech 0.95 kg/mm springs. My own stainless spacer that allows the fork cap to be put on with just hand pressure. Modified adjusters (pin removed) that then allow 2 cm compression. I use about 1 cm.
2008 Thrux
2008 Thrux. 1087 TPUSA motor. SOLD
2010 Speed Triple. SOLD
NorthernThrux is offline
post #4 of 52 (permalink) Old 08-24-2010, 07:25 PM
Main Motorcycle: '08 Scram
Other Motorcycle: What!?!?
08 Scrambler. Stock springs. Ricor Intimators installed w/ 5W Amsoil Shock oil at 130mm below top of fork. Thruxton preload caps added. 196mm spacers (stock is 235mm). No hunting up 'n down on smooth roads.
I think the springs are too soft for me (210 lbs), cos I had to crank on some preload to get appropriate sag. I plan on stiffer springs - when I can stop procrastinating.
'08 Scrambler. Arrow 2-1, ARK, AI gone, thrux needles, 150/40.
thistle66 is offline
post #5 of 52 (permalink) Old 08-24-2010, 08:45 PM Thread Starter
ohiorider's Avatar
Thanks to all for responding. Hopefully we'll hear from a few more, especially those who have had the 'hunting' issue. It's a strange thing .... I'm at 120mm below top of fork, did the spacer calculation as several of us that installed the Intiminators determined proper, yet still have the oscillation in the front forks .... not side to side, slightly up and down. If you were to ride my bike on a smooth surface, and take a look at the wheel and forks, you'd see them working .... up and down.
Bob
post #6 of 52 (permalink) Old 08-24-2010, 10:25 PM
Main Motorcycle: 08' Bonnie
08Bonnie's Avatar
Bob,
I had the same problem as you and I suspected it had something to do with the preload i had to add to get the correct sag #'s. The front end felt nervous over seemingly perfect asphalt after installing intiminators. I finally fixed this by going to the Traxxion springs recommended for my weight. I set the 5w oil 140mm from top of tube. End result is in the numbers; with 1" LESS spacer (less preload) i was able to get 25mm of free sag and about 35mm of rider sag, generally accepted to be pretty good.
The bike now reacts exactly as you'd expect it to over any kind of road surface. I think this has to do with the spring not been overly compressed. With less preload on it, it can now do it's job.
This worked for me. I have an 08' Bonnie and my rider weight is about 185lbs.
Various stuff...
08Bonnie is offline
post #7 of 52 (permalink) Old 08-24-2010, 11:02 PM
Main Motorcycle: '05 T100
Schulte's Avatar
Other Motorcycle: 05 America,07 Yamaha FJR
Here you go...
No
130 mm
Yes
No, Racetech 1.0 kg/mm
05' Bonnie
Schulte is offline
post #8 of 52 (permalink) Old 08-25-2010, 02:28 AM
Main Motorcycle: My 09 Bonneville Black
Other Motorcycle: Want the new CB1100
Thumbs up
Great thread idea.
LuckyBonnie is offline
post #9 of 52 (permalink) Old 08-25-2010, 03:03 AM
Main Motorcycle: two wheeled
grumpy_1944's Avatar
Other Motorcycle: Bonneville black
Extra Motorcycle: thumper
I don't remember specific settings but, stock springs, 5 wt fork oil, everything else follows installation instructions to the letter. Bike was "nervous" in corners prior to intiminators. Also installed Hagon rear shocks. Bike is now more capable than I am.
Bill;
I took the road less traveled---------now where in the hell am I??
grumpy_1944 is offline
post #10 of 52 (permalink) Old 08-25-2010, 11:01 AM
Main Motorcycle: 2007 Triumph Bonneville
mightydaj's Avatar
Other Motorcycle: 1974 Norton 850 Commando
Extra Motorcycle: 1967 305 Honda scrambler
No.
Yes.
Yes.
Yes.
Bonnie.
Sorry to hear of your problem, have not had same problem. Ride much better than with just progressive spring. Some day I will test out Ricor and progressive springs (put stock springs back in when I installed the Ricors).
mightydaj is offline
Ricor Intiminator Review IrlMike Hinckley Classic Triples 67 08-12-2015 09:32 AM
Ricor Intiminator review NorthernThrux Air Cooled Twins Technical Talk 8 05-27-2010 11:45 PM
Ricor Intiminator Review IrlMike T3 Sport / Touring Forum 1 11-30-2009 11:25 PM
Ricor Intiminator Review Southernrocker57 Air Cooled Twins Talk 0 08-26-2009 02:31 PM
Ricor Intiminator davevv Air Cooled Twins Talk 4 05-31-2009 06:45 PM
