my petcock is leaking gas - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 13 (permalink) Old 02-21-2010, 05:19 PM Thread Starter
Forum Liaison
Main Motorcycle: XT1200Z
BlackTigNYC's Avatar
Other Motorcycle: Duc?
it's leaking right out of the face of the dial
just thought I would share the info in case a bunch of other people are having this issue
you are not alone!!
coincidentally i just bought a spare petcock but it was supposed to be for another project. Now it looks like i might just have to replace this one
BlackTigNYC is offline
post #2 of 13 (permalink) Old 02-21-2010, 05:35 PM
Main Motorcycle: Bonnie
Dave2001's Avatar
Mine's not leaking from the face, but it won't fully turn off. Just as well the float needles are in good nick!
I've had it apart, and the plastic inner section seems to have had a groove worn in it which is allowing the fuel to seep past presumably there was a bit if grit or swarf in there (I've had it from new) as it was originally quite stiff. It's a sort of cone shape with an O ring on the outside, so it may be an easy fix on yours if you pull it apart. I don't need to tell you to empty the tank first though
Dave2001 is offline
post #3 of 13 (permalink) Old 02-21-2010, 07:09 PM
Main Motorcycle: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
Pet Cock
Those little buggers are touchy in some cases. I make a habit of turning them to both main and reserve and working them a bit by repeating and loosening them each time i use the bike.
They can become clogged with fuel residue making them sticky and stiff to operate.
You might try taking yours off and taking it apart and cleaning it some. I've read posts where they will work on reserve and not main and vice versa.
Also be aware that some tanks will experience a flaking of the interior tank coating and will clog reserve screens. You can get a borelight or flashlight and inspect the inside of your tank through the filler cap. If you see small grey flecks drifting around the bottom, you may want to drain and remove the petcock for cleaning and flushing the tank out. Done mine twice that way, others have had warranty replacements of tanks with similar problems.
Sitting on a cornflake waiting for the van to come!
koifarm is offline
post #4 of 13 (permalink) Old 02-21-2010, 08:57 PM
Main Motorcycle: 2001 BONNIE
Get over it, buy a Pingel, won't leak, looks great, and as smooth as a babies but
Think BIG!
Hoopla
Investing in a better Bonnie one step at a time
HOOPLA is offline
post #5 of 13 (permalink) Old 02-21-2010, 10:00 PM
Main Motorcycle: T100, number 24
woodwardpj222's Avatar
I agree with Hoopla.
I've been using a PINGEL for over four years. Wonderful piece of gear.
Although they are made for high volume flow they also look fantastic and work really well. Stick a Monza cap on the top and you've got a classic tank.
Woody ... go hard or go home
woodwardpj222 is offline
post #6 of 13 (permalink) Old 02-21-2010, 10:42 PM Thread Starter
Forum Liaison
I'm going to be swapping out the tank soon anyway so I'll probably buy the pingel and put it on the other one. I don't want to fix this POS petcock only to have it happen again.
thanks for the tips
post #7 of 13 (permalink) Old 02-21-2010, 10:56 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
Think BIG!
Hoopla
Agreed. The petcock on my 2003 T100 feels like it is super-glued if I leave it shut off for a few days, then try to turn it to the open position. On the other hand, my old Beemer has twin petcocks, one on each side of the fuel tank. The bike is nineteen years old, and both of them still work as well as they did when new.
I have to think Triumph took the cheap route on the petcocks they installed at the factory during the first few years (or did install, since the new FI machines don't require them). Perhaps they installed improved petcocks later in newer machines ..... I don't know.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #8 of 13 (permalink) Old 02-21-2010, 11:00 PM Thread Starter
Forum Liaison
Bob
in addition to this issue my petock also is hard to turn
my bike is a 2008
I don't think they did jack **** in terms of improving it
post #9 of 13 (permalink) Old 02-22-2010, 03:57 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
Make sure that bolts holding the petcock on too the fuel tank, and the one screw on the side of the p/c are tight, or you could be leaking from them.
Ride safe,
Quentin
wenzel850 is offline
post #10 of 13 (permalink) Old 02-22-2010, 04:53 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
Bob
my mates 1974 Beemer petcock became stiff after he started using E10 fuel. must have viagra in it.
and Triumph petcocks on later models are no better than the earlier ones, ie crap.
BTW what the #### is a Pingel
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
bonne vac petcock? Canyon Motorcycles Maintenance & Workshop Talk 3 06-07-2009 12:53 PM
Petcock is sticky. Tsunami68 Hinckley Classic Triples 10 09-17-2008 03:50 AM
Leaking Petcock dmathers T3 Sport / Touring Forum 3 07-10-2008 08:48 AM
Petcock, who do I believe? Thruxtonian Air Cooled Twins Technical Talk 37 10-29-2007 06:22 PM
Wot!? no petcock?? Maintenance & Workshop Talk 9 10-23-2002 10:39 PM
