Regulator / Rectifier upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 35 (permalink) Old 12-09-2009, 02:52 PM Thread Starter
Main Motorcycle: 2009 Bonneville T100
SR.MailMan's Avatar
Other Motorcycle: 2011Yamaha Star250 bobber
Extra Motorcycle: 2010 DF250RTB(sold)
I did this up grade and was able to use the stock mount location (thanks to dremel tool to relieve one outside area,to allow stock screw to fit).
The bike now charges at idle!
I bought the kit from: www.roadstercycle.com
all new parts included. Nothing but the best for my bike...
SR.MailMan is offline
post #2 of 35 (permalink) Old 12-09-2009, 03:47 PM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
Can you repost the link in a new post? The link you have posted as a title doesn't work. I'll change the thread title once I have an idea what to change it to.......
Looks like a regulator / rectifier upgrade? I'd like to know more about that.
Before he did it, I'd have said it couldn't be done.
propforward is online now
post #3 of 35 (permalink) Old 12-09-2009, 04:10 PM Thread Starter
SR.MailMan's Avatar
I got this link from one of your posts.
http://www.triumphrat.net/maintenanc...r-upgrade.html
post #4 of 35 (permalink) Old 12-09-2009, 04:21 PM
Motorcyclist
Supernova
Oh THAT one! That's by DeCosse - yeah that's a good article that. I'm thinking of doing that myself.
How did it go for you? That looks like a pretty nice kit that you got. You went with the "Triumph" kit I assume?
post #5 of 35 (permalink) Old 12-09-2009, 04:43 PM Thread Starter
SR.MailMan's Avatar
The 3' 10 guage pig tail was too short,to reach the battery,so I connected to the hot side of the starter solenoid. (I chose not to fuse the hot lead. If I did,I could make it reach the battery)
I used lots of dielectric grease, at the rectifier/regulator connections, because they are now outside the headlight shell. The kit does have water tight wire grommets included. I also soldered the three alternator wires to the included spade connectors, that go inside the included connector. A very factory looking mod.
post #6 of 35 (permalink) Old 12-09-2009, 06:05 PM
Main Motorcycle: 1974 Schwinn U24 Unicycle
Flaco's Avatar
Other Motorcycle: '05 Bonneville Bobber
Extra Motorcycle: '05 Bonnie Black Cafe
Looks good,
Nice job...
I like...
All I did was move the rectifier from the lower triple tree to the lower Br-Cu air box lower "tab" w/ no problems in the 107 degree AZ heat...
Chooglin' two '05 Bonnie's…
Goodwood Green 73 RWHP Soft Tail Bobber…
BB Cafe Racer…
"Must go faster!"
Flaco is offline
post #7 of 35 (permalink) Old 12-09-2009, 06:32 PM
Motorcyclist
Supernova
Did you put your new rectifier in the old rectifier position?
EDIT: DUH! yes, you said so in your first post!
post #8 of 35 (permalink) Old 12-10-2009, 10:40 AM
Forchetto's Avatar
This mod might not be worth doing on the newer models. Check with a multimeter first to see if the charging system is doing its thing.
For example on my 2009 Bonneville SE the readings are as follows:
At idle, 1000 rpm with lights on, the battery is receiving 13 volts.
Even with the grip heaters on maximum there's still 12.96 volts there.
Both of these voltage levels ensure a modicum of charge, even at idle.
At just 1400 rpm the full charging voltage of 14 volts appears across the battery terminals.
From this you can deduce that the charging system, at least on these models is more than up to the job.
Forchetto is offline
post #9 of 35 (permalink) Old 12-10-2009, 01:05 PM Thread Starter
SR.MailMan's Avatar
In the New England winters, some of us riders use electric garments(gloves,vests,chaps,grips) and while the stock charging system may be sufficent in the "sun belt", it does not cut it here. My bike idles at the output your bike does at 2000rpm. At speed, My bike does close to 15volts.
Triumph cut back on the quality of the wiring to save production money and I only replaced their mistake.
post #10 of 35 (permalink) Old 12-10-2009, 01:20 PM
Main Motorcycle: 2006 bonneville cafe'd
AJF1134's Avatar
Other Motorcycle: 2006 BMW R1200 GS
For those of you who relocated you r regulator to the area where air box used to be was there enough stock wiring to make the run or did you have to do some splicing?
anyone have pics of any key relocation ideas other than the standard kits you see at new Bonnie or bellacorse ?
05 bonneville british racing green, AI removed, air box eliminated , 19 tooth front sprocket , british customs predators , NH M bars , napoloean bar end mirrors, chrome front fender , eyelid visor, thrux gel seat , lsl rearsets , chrome chain guard
AJF1134 is offline
Charging System Diagnostics - Rectifier/Regulator Upgrade DEcosse Speed Triple Forum 14 09-07-2015 08:52 PM
Upgrade Regulator Rectifier Install WardenRoss Maintenance Tips and Tricks for your Sprint 68 12-21-2012 04:34 PM
Regulator AND Rectifier FifeTiger Tiger Workshop (archive) 1 10-09-2009 11:05 AM
regulator rectifier help evalu8or Air Cooled Twins Technical Talk 15 07-10-2009 10:03 PM
Regulator/Rectifier GoinPostal Maintenance & Workshop Talk 3 07-31-2008 02:45 AM
