Clear turn signal lenses - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 18 (permalink) Old 06-25-2009, 12:32 PM
Main Motorcycle: 05 Black Speedmaster
Originally Posted by RonL View Post
I've tinted lights before. Usually, I add a little black to regular automotive clearcoat and spray on a couple of coats. They come out nice and shiny and once they're cured, they wear like normal clearcoat so they can be washed/waxed/etc. Also good thing is that other chemicals won't wash it off like some other tints out there.
Could you spray them on the INSIDE and not need the clearcoat ? Might try that.
Normandy is offline
post #12 of 18 (permalink) Old 06-25-2009, 01:09 PM Thread Starter
Main Motorcycle: 2004 Speedmaster
Modolicious Moderator
marc hanna's Avatar
^^ That works well on clear lenses but not that well on coloured. It is useful for making the light appear a different colour when illuminated, ie, blue tint on the inside make a red lens appear purple when lit.
I wonder if the new thunderbird clear lenses would fit ???
Nope. Doesn't look like.
UNI pods, AI removed, de-baffled TORs, relocated battery, custom bobbed fender, custom wiring, etc
marc hanna is offline
post #13 of 18 (permalink) Old 06-27-2009, 01:13 AM
Main Motorcycle: mine
I have clear lenses on my 05 America , got them on UK EBay from "classic " something ,sorry parts or spares it was ,they are "Lucas"repo indicator lenses , you have elongate the hole a couple of mil
boofhead is offline
post #14 of 18 (permalink) Old 06-27-2009, 03:02 PM Thread Starter
marc hanna's Avatar
Was the vendor called "Classic Bits"?
Do you remember specifically which model # the lenses were?
post #15 of 18 (permalink) Old 06-27-2009, 04:35 PM Thread Starter
marc hanna's Avatar
Yup, it appears the Lucas L760 lamps will fit our bikes with a modification of the screw holes. Even better, these are available in real glass!!!
post #16 of 18 (permalink) Old 06-28-2009, 12:34 AM
Those lenses come in RED,CLEAR,AMBER
They were used on mini moke and land rover and other Morris things
how would you go fixing the holes in the class ones , might be tricky
boofhead is offline
post #17 of 18 (permalink) Old 06-28-2009, 10:48 AM Thread Starter
marc hanna's Avatar
Carbide or diamond burr would do it.
post #18 of 18 (permalink) Old 06-28-2009, 02:50 PM
Main Motorcycle: 2007 America
I too went with the Lucas lens (Red). I had put on the Signal Minder and wanted to use the running light option with the turn signals but Ohio (USA) does not like Ambers that are constantly on.
Found them on E-Bay. The holes were just a tad off. Nothing a small Dremel adjustment could not fix. Looks good with all red in back plus all on and all work as brake lights. Wayne
b315653 is offline
Clear Buell signal lenses sailfish T3 Sport / Touring Forum 1 06-05-2008 12:23 AM
Team Triumph clear signal lenses for an '01 Hokie Sprint Forum 4 11-14-2007 10:18 PM
Clear Turn signal lenses for the Bonneville? Brk4moose Air Cooled Twins Technical Talk 2 07-27-2006 03:42 PM
Need Clear Turn Lenses for "03"??? K3 Speed Triple Forum 2 05-12-2006 12:31 AM
Where to buy clear turn signal lenses? Bob_N Air Cooled Twins Talk 3 12-26-2005 06:15 PM
