DIY - EFI Bonnie Gas tank removal and cam cover replacement (lots of Pics) - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
post #41 of 51 (permalink) Old 05-27-2012, 10:13 AM
Main Motorcycle: All
Why does the orange clip need to be removed from the tank?
WTBScrambler is offline
post #42 of 51 (permalink) Old 05-27-2012, 10:26 AM
Main Motorcycle: 2008 Bonneville
WTBscrambler. The orange clip secures the rubber fuel line to the metal outlet tube on the tank.
Trumpie is offline
post #43 of 51 (permalink) Old 05-27-2012, 01:13 PM
Forchetto's Avatar
It doesn't, see post 32 for a close-up look at these fittings. If you have fat fingers it might be more difficult to operate the two release buttons though, in which case removal of the safety clip will help. On cars, where there's a lot more room, mechanics often use special pliers for these quick-release fittings:
Forchetto is offline
post #44 of 51 (permalink) Old 09-18-2012, 09:36 AM
Main Motorcycle: 2009 Triumph Bonneville
Cruzin1a's Avatar
Fantastic write up :0) In this post there was a reference to the torque setting for the torx bolts on the cam cover. Can someone clarify what that torque setting should be?
Cruzin1a is offline
post #45 of 51 (permalink) Old 09-18-2012, 02:09 PM
Forchetto's Avatar
Older manuals specify 10 Nm (7.37 Ft/lbs). That figure has been revised to 14 Nm (10.32 Ft/lbs).
post #46 of 51 (permalink) Old 11-21-2012, 08:27 PM
Main Motorcycle: 2011 America
photon's Avatar
Other Motorcycle: Not Yet
Thank you for your previous post! Your 2009 Post is going to be of great assistance to me now in installing my new Driving Light for my 2011 America. 1st step: Remove the gas tank. Thanks!
Cheers
photon is offline
post #47 of 51 (permalink) Old 11-21-2012, 11:44 PM
Forchetto's Avatar
I think member Pauljp's video showing the tank removal procedure for EFI Bonnies makes a good addition to this thread. It's on a link in post 1 here:
http://www.triumphrat.net/twins-tech...val-video.html
post #48 of 51 (permalink) Old 12-01-2012, 07:21 PM
Main Motorcycle: "Thai" Triumph T100
Other Motorcycle: Previous: 1970 Bonny
Extra Motorcycle: Learned on Sports Cub
Hi great post - worked like charm. The fuel line connector was a little tricky but other wise straight forward. Getting rid of all that air junk off the top of the engine makes it all look cleaner. However in my kit I had 4 black plastic nipples for putting over 1/8 tube I guess - but I did not disconnect anything that needed them and can find no instructions as to what they are for?
Bike runs great and no popping on the overrun.
wyomingpat is offline
post #49 of 51 (permalink) Old 04-24-2013, 10:01 PM
Main Motorcycle: 2008 Sprint ST
Other Motorcycle: 2013 Street Triple R
I don't think this was mentioned in the thread anywhere, but does anyone recall what size hex head is used for the cam cover bolts? I'm getting ready to change the gasket and washers/rings and will need to get the appropriate head for my torque wrench. Also, any recommendations on what to use to help seal the gasket?
Thanks!
Famer is offline
post #50 of 51 (permalink) Old 04-24-2013, 11:01 PM
Forchetto's Avatar
Thanks!
T30 Torx-head bolts. The gasket is fitted dry. Some people use a smear of silicone sealant but if the bolt seals are in good condition there's no need for any.
Tornado Red ST with red Baglux tank cover pics ? whoosh Sprint Forum 0 05-10-2007 06:43 AM
Bad Sputter after Tank & Airbox Removal/Replacement LoanArranger Sprint Forum 8 03-26-2007 11:03 AM
fuel tank removal/replacement question boocat Tiger Workshop (archive) 3 12-03-2006 01:40 PM
Sixty8 tank cover pics.... Hozer Club Cafe' 9 08-19-2006 09:44 PM
Pics of Buell Lightning Mirrors (Warning: Lots of pics) Maintenance & Workshop Talk 1 10-16-2005 04:15 PM
