2001 bonnie clutch chatter - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 28 (permalink) Old 05-11-2009, 08:00 AM Thread Starter
any body that has one that chatters in 1st gear when your in traffic and your using the clutch,,,,the early ones did this, mine did, the fix is a new push rod that hits the push rod seat the old push rod is round at the end the new one looks longer and the end is shaped like the seat i tryed to fix it a couple years ago and no one knew any thing so this year i gave it another try i called greatbay triumph and al knew what i was talking about and sent me the part you also need the clutch cover gasket, oil , filter and crusher washer about
130 bucks , my guess it might take the dealer an hour , greatbays in north hampton NH,
THANKS AL.
ohyea the clutch cable gets shorter i had to stick it in the linkage before
i bolted it down but you might need one
kurtisf is offline
post #2 of 28 (permalink) Old 05-11-2009, 09:39 PM
i've got an '01, but have never experienced clutch chatter. i've heard that this is common problem for our vintage, however. it's good to know it can be fixed relatively easily. thanks for the info. i'll subscribe to this thread for future reference.
2005 Triumph Bonneville T-100
pretty much stock to the bone, 'cept for some af turn signals... so far.
metasac is offline
post #3 of 28 (permalink) Old 08-07-2009, 12:20 AM
Main Motorcycle: 2011 t-bird storm
Mine seems to be doing exactly same thing. Thanks for the heads up, gonna check that out asap. By the way -greetings to all (first timer)
jabol is offline
post #4 of 28 (permalink) Old 08-07-2009, 01:08 AM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
A good riding buddy of mine owned one of the first Bonnies in the country ( he placed his order long before they were on showroom floors). Not far into ownership, perhaps 5000 miles, his bike would start off in first gear with a 'clunk, clunk. clunk' sound and feel.
Not sure about the repair, but I believe it was fixed under warranty. It may have involved replacing some parts, perhaps the clutch basket .... don't recall. However, this fix should be on file with Triumph, so you should be able to get info about it.
Once fixed, it was fixed for good. He didn't sell the bike until 2007, by which time it had nearly 28000 miles on the clock.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #5 of 28 (permalink) Old 08-07-2009, 02:50 AM
Forchetto's Avatar
Not sure if it's applicable, but on Jap four cylinder bikes out of balance carbs would shake the clutch drum and produce a characteristic clatter at idle and low revs. Balancing carbs cured it.
Forchetto is offline
post #6 of 28 (permalink) Old 08-07-2009, 03:33 AM
Main Motorcycle: 05 T100
Not really. This is a known problem with the (very) early bikes that Triumph has a fix for and any decent dealer should have access to the required info and parts to fix (but there seem to be a lot of crappy dealers about, particularly in the US). I believe Triumph are still fixing this under warranty, but I wouldn't swear to it. It's not something that owners of post 01 bikes really need to worry about.
Paul.
Herts. UK
PAAS is offline
post #7 of 28 (permalink) Old 11-17-2012, 03:03 PM
Main Motorcycle: 2001 Triumph Bonneville
Re: clutch pushrod replacement
THANKS AL.
I don't suppose you have the part number for the replacement pushrod? I have the same problem. Regards
jamessymes is offline
post #8 of 28 (permalink) Old 11-17-2012, 03:28 PM
Forchetto's Avatar
kurtisf has not been in the forum since 2009. If it's any help World of triumph parts locator has 3 options for that part, items 18 on the listing/drawing below.
There are some engine numbers showing up to which engine the different parts were used.
To get the proper factory part number you need to press "add to cart" then click on the name or description that appears and that takes you to another screen with the part number:
http://www.worldoftriumph.com/triump...&block_03=3130
post #9 of 28 (permalink) Old 11-17-2012, 03:42 PM
Thanks so much. That's a great help. New here. Trying to get my 2001 Bonne all sorted. I wonder which of the three listed parts he fitted?
Regards
post #10 of 28 (permalink) Old 11-17-2012, 03:55 PM
Forchetto's Avatar
Regards
Somebody must know this. Mikeinva knows these engines inside out and I hope he reads this thread.
In the meantime we'll try and keep the thread visible by "bumping" it for a couple of days...
Clutch chatter Yelwoh The Rocket Science Forum 3 09-12-2007 06:17 PM
Clutch Chatter Bobnoxious Air Cooled Twins Technical Talk 17 06-29-2006 01:40 PM
Clutch Chatter SbGunslinger Air Cooled Twins Talk 0 05-24-2006 09:06 PM
Clutch chatter farky Air Cooled Twins Talk 2 05-13-2006 01:42 AM
Clutch Chatter Odysseus Air Cooled Twins Talk 7 10-15-2005 01:07 PM
