Replacing HandleBar Grips - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 01-11-2009, 12:42 PM Thread Starter
Main Motorcycle: Thunderbird 1600
Can anyone tell me the easiest way to remove my stock handlebar grips on Speedmaster and how to put on new ones. I would like to put the vintage grips on. Do I need a special glue. I heard hairspray works good.
cocoselect is offline
post #2 of 17 (permalink) Old 01-11-2009, 12:49 PM
Main Motorcycle: 12 NC700X
02redbird's Avatar
Other Motorcycle: 02 KL250G
compressed air works
a bit of soap and water then air shot near the edge of the rubber will lift it enough to be removed. Same with back on.
Eric
"You're going too fast young man. Me? fast? I only look fast."
02redbird is offline
post #3 of 17 (permalink) Old 01-11-2009, 01:28 PM
Main Motorcycle: 1965 TR6SR
rmak's Avatar
Other Motorcycle: 2007 Scrambler
Just a little refinement on what cocoselect said. I work a small screwdriver between the grip and bar. Then I lift it and shoot in some windex. If you work the screwdriver around it works the soap around too. Be careful not to puncture the grip. If it's stubborn, I have shot some compressed air. Once again, lifting that screwdriver helps get the air in as well.
I use artist spray adhesive. Be sure to clean the soap out of the inside of the grip if you would reuse them at any point.
Of course, if you're never going to use the grips again, you can just cut them off. Wouldn't recommend that though.
rmak is offline
post #4 of 17 (permalink) Old 01-12-2009, 08:33 AM
Main Motorcycle: 2008 t100
Other Motorcycle: 2009 Moto Guzzi Norge
Contact cleaner and compressed air works great to remove grips as well
2008 T100 B/W, centerstand, Flanders narrow cafe bars, Manic Salamander barend weights, Russell Seat, Works Performance Shocks, RaceTech Fork Springs and Emulators, A I removed, desnorkled, Dominator Touring exhaust, 118 mains, no shim, 2 3/4 turns
Olderslower is offline
post #5 of 17 (permalink) Old 01-12-2009, 10:13 AM
Main Motorcycle: 06 Bonnie T100
nick_t's Avatar
Other Motorcycle: I only got one...
just did this on my bonnie -- i used WD40 to get the suckers off, and a whole lot of grunting and swearing to get them back on. i tried hairspray, but found it not very helpful -- the size of the grips keeps them in place, no problem.
removing the grips is a really easy thing to do. go for it!
nick
"Each day is a journey, and the journey itself home."
-- Matsuo Basho
06 Bonneville T100 (AI removed, snorkel IN, DualStar hotgrips, stock otherwise)
nick_t is offline
post #6 of 17 (permalink) Old 01-12-2009, 01:01 PM Thread Starter
How do you get the WD4 underneath the grip.
post #7 of 17 (permalink) Old 01-12-2009, 08:07 PM
Main Motorcycle: 11 Speed Triple
Billbikes's Avatar
Other Motorcycle: 05 Racing Yellow Thruxton
Hairspray
I've always used hairspray on my bikes.
You can use the same trick as with the wd40, but you don't have to make sure you get them really clean when you're done. It's slippery when wet and sticky when dry......
11 Speed3 Arrow Low Exhaust
05 Thruxton TPUSA Exhaust, ARK, Rear Fender delete, Woodcraft Clipons
You can take the boy out of Texas, but you can't take Texas out of the boy.
Billbikes is offline
post #8 of 17 (permalink) Old 01-13-2009, 12:56 PM
nick_t's Avatar
just take something slim and long, like a small flathead screwdriver or a chopstick and wedge it under the grip. the rubber will flex upwards and not be damaged, then just squirt some WD40 or hairspray in there and give it a tug. should come right off.
oh -- the throttle side is a little harder since the rubber sits on the plastic throttle assembly, but it should work just the same. maybe be a little more gentle with the throttle side so you don't damage the plastic underneath.
cheers.
nick
-- Matsuo Basho
nick_t is offline
post #9 of 17 (permalink) Old 01-13-2009, 10:07 PM
Main Motorcycle: 2002 Bonneville 790
Other Motorcycle: 2006 HD FL
Extra Motorcycle: 1981 BMW
Thumbs up try carb cleaner
Yep, a shot of carb cleaner ( careful of painted surfaces) between the grip and the bar and it will slide right off. Insert a screw driver to lift the edge, spray a few areas , and slide it off. Same with installation. A shot of carb cleaner ,slide it on and it sticks like glue.
jerseyjeff is offline
post #10 of 17 (permalink) Old 01-13-2009, 11:44 PM
Main Motorcycle: 2007 Bonneville
El Moderatore
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
Very timely thread for me as I am about to do the same when my New Bonnie Black Clubmans get here......
I am trying to understand the throttle grip...... and I have no idea about it since I have never taken it apart. What is the grip actually on since it rotates freely? Can I just slide the whole throttle assembly and grip off the end if I loosen it from the bars and take off the bar end?
Calliway is offline
Handlebar grips dikman Air Cooled Twins Technical Talk 3 08-04-2008 03:05 PM
Replacing throttle tube and grips. Fraederichs Air Cooled Twins Technical Talk 1 09-30-2007 03:42 PM
Replacing grips/grip warmer kelticwolv Sprint Forum 3 01-24-2005 11:59 AM
Any Tips for Replacing Grips? MikeWS1 Sprint Forum 7 04-03-2004 09:29 PM
Handlebar Grips Hinckley Classic Triples 1 03-25-2004 05:09 PM
