Replacing HandleBar Grips - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 01-14-2009, 09:44 AM
Main Motorcycle: '09 Mystery Black EFI
teachnsurf's Avatar
Originally Posted by Calliway View Post
Very timely thread for me as I am about to do the same when my New Bonnie Black Clubmans get here......
I am trying to understand the throttle grip...... and I have no idea about it since I have never taken it apart. What is the grip actually on since it rotates freely? Can I just slide the whole throttle assembly and grip off the end if I loosen it from the bars and take off the bar end?
You betcha.
This is my Bonneville. There are many like it, but this one is mine. My Bonneville is my best friend. It is my life. I must master it as I must master my life. My Bonneville, without me, is useless. Without my Bonneville, I am useless.
teachnsurf is offline
post #12 of 17 (permalink) Old 01-14-2009, 03:08 PM
Main Motorcycle: '06 Thruxton
neuroboy74's Avatar
Other Motorcycle: it has pedals.
i usually use windex.
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline
post #13 of 17 (permalink) Old 01-14-2009, 11:50 PM
Main Motorcycle: 99 Harley Softail
Other Motorcycle: 04 Triumph America
Extra Motorcycle: 66 BSA Spitfire Chopper
just did mine. pour boiling hou water over the old ones, and they slid off pretty easy. Put the new ones in hot water (not boiling) for a few minuets, and they will slid on
forrestnb is offline
post #14 of 17 (permalink) Old 12-06-2012, 06:04 PM
Newbie
Main Motorcycle: Bonneville T100 McQueen
Grip question
I've read many posts about using the air compressor/WD40 to get grips on and off. Any recommendations for the hard plastic grips on the McQueen T100? The grips aren't really flexible enough to get a screwdriver between the grip and the bar and there isn't enough space to get at it from the flanged end.
Also, any recommendations for a more comfortable 1" grip that fits with the McQueen subdued style? Thanks!
Onlegendary is offline
post #15 of 17 (permalink) Old 12-07-2012, 01:51 AM
Main Motorcycle: 2010 Bonneville
I did this not 2 weeks ago, as mentioned in other threads get some canned air, remove any screws from the grips. Work the spray air tube under the end of the grips.
Squirt the canister and the grips will inflate like a balloon - whilst this is happening wiggle them gently off. If you know your new grips are ok, just cut the old ones on.
WD40 to get the new ones on - had no issues with slipping - I found it a real bitch to get them on and used a fair amount of wd40
Mr*Beaver is offline
post #16 of 17 (permalink) Old 09-02-2014, 04:05 AM
Main Motorcycle: 2010 Bonniville SE
BonnieK's Avatar
did I order the right new grips
The grips in thumbnail from Third Gear arrived today. They are about a quarter inch shorter than the stock ones. I've put bar end mirrors on and I put locktite on threads....great )
Have Genmar riser coming from NewBonneville which may take up to 4 more weeks to arrive but want to put grips on now/tomorrow.
My question is;with the new grips being a tad shorter would loosening off the bar clamps (controls) and just pushing them closer work...yes/no? But when the risers go on will there be enough slack in the cables remaining or do I return the cute grips?
Name:	GRIPSILV02 third gear yummy.jpg
BonnieK is offline
post #17 of 17 (permalink) Old 09-03-2014, 11:36 AM
Main Motorcycle: 2006 T100
endoscopy's Avatar
Other Motorcycle: 1969 TR6R
Getting a Grip
Mr. Calliway,
To answer your question about the throttle.
The throttle grip is the same as the left hand side except that it is inserted over the throttle sleeve. That sleeve just rotates on the handle bar and is held captive by the ear which holds the throttle cable ends that rotates in the housing.
I might be wrong but I doubt that the whole assembly can come off with the cables attached. There is probably not enough slack in the cables. It would net you nothing anyway as with the assembly in place on the bars, it gives you a firm platform to remove the grip.
I personally use rubbing alcohol and compressed air for grip work.
Namaste,
Charles
endoscopy is offline
Handlebar grips dikman Air Cooled Twins Technical Talk 3 08-04-2008 04:05 PM
Replacing throttle tube and grips. Fraederichs Air Cooled Twins Technical Talk 1 09-30-2007 04:42 PM
Replacing grips/grip warmer kelticwolv Sprint Forum 3 01-24-2005 12:59 PM
Any Tips for Replacing Grips? MikeWS1 Sprint Forum 7 04-03-2004 10:29 PM
Handlebar Grips Hinckley Classic Triples 1 03-25-2004 06:09 PM
