Brake bleeding problems - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 30 (permalink) Old 12-22-2008, 01:12 AM Thread Starter
Main Motorcycle: 05 Triumph Speedmaster
Other Motorcycle: 03 Triumph Americia
Extra Motorcycle: 97 Kawasaki KLX300
I've been a member sinse 05 and I've been browseing for information when I need it every sense. I appreciate all the great information and I apoligize that I have not posted till now. I usually manage to get by but this time Im going to need help.
I have a 05 speedmaster of my own. But at the moment I'm working on a 03 Americia for my little brother. And as I'm putting it together. I can not get any pedal on the rear brake. I've refilled the Resevoir over ten times. I'm not getting any more air out of the bleeder. And the pedal still goes straight down and bottoms out.
There is no leaks, No lost fluild and its not taking in air. So to keep a long story short. I'm looking for a second opinion. Do I need to replace the piston kit inside the master cylinder? Does anybody have experiance with this?
Thank you,
Mathew Watts
MWatts9728 is offline
post #2 of 30 (permalink) Old 12-24-2008, 01:47 PM
tridentt150v's Avatar
It could be that the m/c piston seal is stuffed, going on what you said that would be my opinion?
Try taking the caliper off [don't disconnect the hose though] and turning and twisting it around then put it back on and see if you get any air, they sometimes trap air in them.
Also try posting in the metric twin forum part?
tridentt150v,
Great Southern Land.
tridentt150v is offline
post #3 of 30 (permalink) Old 12-24-2008, 02:15 PM
Legend
I took the liberty of moving this thread to the appropriate forum.
If you've refilled the reservoir more than once or twice, you DEFINITELY have a leak.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is online now
post #4 of 30 (permalink) Old 12-24-2008, 10:32 PM Thread Starter
Fist off I apoligize GrandPaulZ. For placing this post in the wrong forum. Thanks for relocating it. Hopefully it will help another person someday.
As far as my brake issues. I got that one solved. This bike was reassembled by me. After the previous owner disassembled it to get some parts chromed and do some impact repairs. So The master cylinder, Ridgid lines, rubber brake line, and caliper were all bone dry when I started.
I was bleeding these brake by hand with my brothers asistance, then switched to a one man brake bleeding bottle. We bleed them for half hour getting all the air out the would come out of the zert fitting. Once the air stopped comming out and we still had no pedal. Then after more bleeding. We suspected the master cylinder. But the next morning we rented a mity vac and got more air. So I relized the possiblity of still haveing air in the system was likley.
I first bleed the brakes at the bango bolt on top of the master cylinder, then again under the bike and the banjo bolt were the final brake line connect to the rigid line, once more at the caliper, and finally reconnected the mity vac to the zert fitting And we got the pedal a pretty good pedal. So sorry for the long story but the problem was still air in the system.
The pedal still isn't the way I would like it to be. It is solid but there is some travel on the pedal before the pressure is felt. Unlike my 05 speedmaster. And before this bike hits the road that problem will be fixed also. The brake pads are still at 80% or better. If it is still more air in the system, or some freeplay adjustment I don't yet.
Thank you all greatly,
Mathew
post #5 of 30 (permalink) Old 12-24-2008, 10:38 PM
Main Motorcycle: 06 Thrux, of course
Other Motorcycle: ZX900 Ninja (gone. sniff)
Matthew, have you tried speedbleeders? Look them up--I just got a set for my thrux and have used them for my 911. They are absolutely invaluable and the best $20.00 you'll ever spend.
J
2009 D675
2010 Duc Streetfighter S (sold)
2006 Thruxton (sold)
sito is offline
post #6 of 30 (permalink) Old 12-24-2008, 11:30 PM Thread Starter
"J" Where did you get the speedbleeders? I asked the guy at the autoparts store and he looked at me like I told him aliens have landed.
post #7 of 30 (permalink) Old 12-25-2008, 12:03 AM
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I had to bleed the rear brake when I relocated the m/cylinder and reservoir due to the Scrambler mods on my T100. I tried for hours to get a pedal,there was a thread on here with some good advice but still I couldn't get pressure. Ended up borrowing a brake bleeding apparatus from a H D store, two minutes and I was finished. The thing I borrowed plugged into an air line and pushed the fluid through. Chances are that your plumbing is good, just need the right buddy to borrow gear off.
Oh,just saw the time. Merry Christmas.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline
post #8 of 30 (permalink) Old 12-25-2008, 09:45 AM
Main Motorcycle: 2008 T100
Brake line air purging
Due to installing handlebar risers on my T100, I had to go to a longer front brake line.
Since this resulted in totally air-filled lines, I used a large syringe with some silicone tubing (model airplane fuel line) connected to the bleeder nipple.
Pulling the brake fluid through from the reservoir does a good job of purging the large volume of air from the system.
As for the speed bleeders; I have them, and IMO, they do NOT work at all!
I tried getting the last bit of firmness in the lever and pedal by depressing them completely with the "speed bleeder" just cracked far enough to allow fluid to flow out. I found that releasing the lever or pedal BEFORE completely closing the "speed bleeder" resulted in air being sucked back into the system.
Ie; the "internal check valves" were NOT working.
So, I do the last bit of bleeding via the old method of applying pressure to the lever or pedal, cracking the bleeder, and closing it again while there is still travel left in the lever or pedal.
I received no instructions of any kind with the "speed bleeders", so if anyone can advise me on any special operating procedure I may be disregarding, fire away!
Bob
bmwbob is offline
post #9 of 30 (permalink) Old 12-25-2008, 09:59 AM
British Customs. Their site is down now else I'd give you the link..You simply unscrew the old nipples, screw in the new ones--important--make sure you stop when you hit resistance else they'll strip--then you unscrew 1/4 to 1/2 turn , connect a bottle with a hose to it, pump the brakes while you add new fluid (different color helps) until you see it coming into the bottle, screw the bleeder back in and bob's your uncle.
No air can get back into the bleeder with its valve. Jack
2009 D675
sito is offline
post #10 of 30 (permalink) Old 12-26-2008, 12:17 AM Thread Starter
I have to go order a new brakeline for the front wheel. And when I get it I'm going to spend more time getting the brakes to 100%. For now I just needed to know the the system works. Before I place an order for parts. The speed bleeder deffinatly sound like an option. But I think I can get this the old fashion way.
Mathew Watts
2005 Triumph Speedmaster, 2003 Triumph Americia, 1997 Kawasaki KLX300, 1993 Husqivarna WXE 350,
1982 Honda XL 250 R, 1971 Honda CT70
Brake bleeding help trumpycam Air Cooled Twins Technical Talk 6 11-09-2008 06:36 PM
Problems bleeding 955 S3 front brake triple3john Speed Triple Forum 3 08-01-2008 05:33 PM
Brake Bleeding Mancha Club Cafe' 12 04-21-2006 12:37 AM
Brake Bleeding clive955 Tiger Workshop (archive) 5 07-23-2005 04:47 PM
Brake Bleeding nyburner Speed Triple Forum 0 06-09-2005 06:21 PM
