Help. Back wheel still engaged while in Neutral - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 07-26-2008, 07:59 PM Thread Starter
Willyrover's Avatar
Hi all
I have the 2008 carby model Speedy and I have been hearing a funny noise while riding like something is rubbing on the wheel. It does not disapear when clutch is pulled in and rolling. When I got home I put it on a stand and started the bike and while it was in Neutral, the back wheel was engaged and running. I confirmed this by trying to stop it with my hand and it was definately in drive mode, It increases with engine revs.
Anyone know what is happening and is it related to the noise I hear while riding ?
Help please.
Derek
2008 Speedmaster (Black)
Willyrover is offline
post #2 of 8 (permalink) Old 07-26-2008, 08:25 PM
Main Motorcycle: 12 Rocket Roadster
Gregger's Avatar
Other Motorcycle: 03 America
The back wheel will turn when the bike is on a stand, engine running in neutral. This is due to residual drag from the oil in your transmission. Even though the output shaft isn't physically hooked up to the input or drive shaft, the oil between them has enough friction to cause it to turn. If you apply the rear brake does the wheel stop? You should be able to hold the rear wheel stopped though.
A noise when driveing the unit can be anything. Do you hear it when you pull in your clutch and throttle back? What does it sound like. Could be from the rear wheel being out of alignment, chain noise, chain too loose rubbing on the swingarm, tire rubbing on the fender....
Can't wipe this smile off my face!!!!
Gregger is offline
post #3 of 8 (permalink) Old 07-26-2008, 08:50 PM Thread Starter
Willyrover's Avatar
Yes the noise is still there when clutch is pulled in and throttle off and just rolling. Sounds like it is coming from the front to middle area of the bike. I have checked all alignments, I have checked for clearances for everything near the wheels and guards etc. Have checked chain cover. It has me baffled. It is not constant and it comes and goes every so often. It is not there at startup but comes in after bike is warmed up while riding. (trying to give as much detail as I can here). The flicking type noise is faster, the faster the bike is rolling if you know what I mean.
I should mention it is a tinny type noise and not a deep note
Derek
post #4 of 8 (permalink) Old 07-26-2008, 09:58 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
maybe you need to adjust the clutch.
sweatmachine is offline
post #5 of 8 (permalink) Old 07-27-2008, 12:45 AM
Is it the light buzzing from the front brake disk or the speedometer cable? Both of these are common. The brake noise is harmless, and the speedo cable can be fixed by lubing it.
Marty
Baltobonneville is offline
post #6 of 8 (permalink) Old 07-27-2008, 08:23 AM
Main Motorcycle: 2015 Bonnie Newchurch.
amanger's Avatar
Other Motorcycle: Aprilia SR Max 300
You need louder pipes ??
2015 Bonnie Newchurch, Staintunes, debaffled and desnorkled airbox TTP #3 tune, J.B.S. Thruxton length shocks, Tec fork springs, Dart screen, Renthal low bars.
amanger is offline
post #7 of 8 (permalink) Old 10-20-2008, 05:18 PM
Did you ever get this figured out? Iím experiencing something very similar, it started when I got my bike back from the dealer following its 500 mile servicing. I canít figure out what the deal is, but the symptoms sound identical. Let me know!
mateo4012 is offline
post #8 of 8 (permalink) Old 10-21-2008, 07:34 PM
Send a message via AIM to CAPTDON
Question Wheel Problem?
You SHOULD be able to stop the wheel from turning w/ your hand on the stand! If not- there is a problem I cant picture in my head? Will have to think about this one?
CAPT D
CAPTDON is offline
TT600 wheel moving in neutral. Kinc Triumph SuperSports 12 01-31-2008 01:24 AM
A question to all you married men / engaged men. Tattoed Red Head Biker Hang-Out 49 09-20-2007 03:48 AM
Got engaged. Now what? shedds Biker Hang-Out 6 01-16-2007 03:38 AM
Back wheel moves in neutral?!?! dkurtz Triumph SuperSports 4 01-06-2007 02:16 PM
Wheel spins in neutral?? pabonne Air Cooled Twins Technical Talk 6 09-21-2006 06:12 AM
