keihin cvk teardown photos/graphics? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 10-17-2007, 11:56 PM Thread Starter
Main Motorcycle: '06 scrambler
sjalex's Avatar
Other Motorcycle: 1980 Vespa P125X "superstock"
Anyone know where I can find a photographed teardown sequence for the keihin cvk carbs? Or an exploded diagram? I just want to know what goes where before I start poking and prodding.
Another thing I'm interested in is the specs for how the carbs connect to the manifolds; I'm thinking mikuni flatslides might be in my future and I don't really like the idea of a "kit" without knowing what's -really- in the kit.
sjalex is offline
post #2 of 16 (permalink) Old 10-18-2007, 12:58 AM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
Google: Keihin CVK
Retro-Racer is offline
post #3 of 16 (permalink) Old 10-18-2007, 01:12 AM
I just finished taking apart my carbs this past weekend and I found the most helpful photos were at this link under the "Carb Jetting" section. Pretty much a step by step guide. To see the top end photos you must click on the "Shimming" link toward the end of the jetting series of photos. You'll see what I mean.
Mike
http://www.dinqua.com/Triumph/carbs0.html
MikeinLA is offline
post #4 of 16 (permalink) Old 10-18-2007, 12:27 PM Thread Starter
sjalex's Avatar
Mike
Nice, thanks. This is much better than my google results :-)
http://www.dinqua.com/Triumph/Shim1.html for a direct link to the shim page. Thanks MikeinLA, and Dinqua!
sjalex is offline
post #5 of 16 (permalink) Old 10-18-2007, 12:32 PM
Main Motorcycle: 02 Bonneville
Other Motorcycle: 1972 Honda CL450 Scrambler
Try here...http://www.gadgetjq.com/keihin_carb.htm
It's for a CVK40, but still applies to ours.
Shorty
Different Strokes, for different folks.
2002 Red & Silver Bonneville
http://i22.photobucket.com/albums/b3...Bonneville.jpg
http://i22.photobucket.com/albums/b3...4/e0d93963.jpg
Shorty is offline
post #6 of 16 (permalink) Old 10-18-2007, 12:50 PM
bonnieblackinfl's Avatar
I can tell you that the 42mm kit from Bonneville Performance is as complete as they come. The only thing the kit lacks is intake couplings. He will also remove things and discount them towards the kit. For example K&N cone filters, if you already have them he would remove and credit you kit price $60, or whatever. Bill Gately is ultra-pro customer too, and he really treats people the way that he would want to be treated if he was a customer.
If you have anymore questions I will be happy to answer them for you.
Greg
bonnieblackinfl is offline
post #7 of 16 (permalink) Old 10-18-2007, 03:20 PM
Oh yeah, Dinqua. Forgot about 'ol Pat. Really good info.
post #8 of 16 (permalink) Old 10-18-2007, 03:55 PM
Main Motorcycle: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a CR&S Vun
Question removing the bowl, with the carb in place?
Does anybody know if it is possible / advisable to remove the float bowls / carb bottoms, with the carbs on the bike?
The reason I ask is that the left side drain screw is messed up (by previous owner). I assume that it will be easier to change the drain screw with the bowl off the carb. Obviously, there would be a need for something to catch the fuel coming out (rags). I have already orderes a new drain screw, and a new seal for the bowl.
'04 T100 used to be B&W, now is Aluminium
904, 813, port&polish, Pieman igniter, rebuilt front (valves, springs, etc), Öhlins shocks, tubeless alu rims, JMC alu swingarm, DeCaesar alu triple trees, MASSmoto pipes, Ti nuts and bolts
- Ringer
TB-T100 is offline
post #9 of 16 (permalink) Old 10-18-2007, 04:29 PM
It's no problem removing the float bowls with the carbs on the bike (it makes it easier if the previous owner installed the hex screws instead of the soft stock Phillips type).
I place a rag underneath and let the fuel drip out after shutting the petcock off.
I also use Hylomar gasket material and haven't had to replace the rubber gasket yet after numerous removals.
Shorty
Shorty is offline
post #10 of 16 (permalink) Old 10-18-2007, 04:34 PM
TB-T100's Avatar
Thanks Shorty. Yup, turning off the fuel-flow is definitely on my check-list for the job. Probably no hex screws though
- Ringer
TB-T100 is offline
Keihin CVK info tbh9088 Maintenance & Workshop Talk 9 12-18-2007 10:05 PM
Keihin CVK-36 Carb spares in the UK? GeoffE Maintenance & Workshop Talk 5 11-29-2007 11:05 AM
650 teardown issue?? tri650 Classic, Vintage & Veteran 19 09-06-2007 04:04 PM
Keihin CVK parts Nzbiker Air Cooled Twins Technical Talk 5 05-18-2007 09:48 PM
Winter teardown JasonS Sprint Forum 3 02-16-2006 11:47 AM
