How to remove stripped nut - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 08-08-2007, 08:34 AM Thread Starter
Main Motorcycle: Triumph Thruxton
itcha's Avatar
Angry How to remove stripped nut
I have stripped the nut that holds one of the rear footpegs, what's the easiest way to remove it please.
itcha is offline
post #2 of 14 (permalink) Old 08-08-2007, 09:14 AM
pair of vice grips?
Bonefide is offline
post #3 of 14 (permalink) Old 08-08-2007, 09:16 AM
the way to do that would be to buy the handy tool known as the "nutcracker" it encircles the nut and applies a sharp edge and it breaks it.
not having one of those, I would dremel into 1 side till the nut could be removed. the most basic form of all these methods would be to chisel it off with a sharp tool and a steady hammer hand. and go easy there mongo, those smaller fasteners dont need to be really cranked on
G
I just wanted to ride
Geoff is offline
post #4 of 14 (permalink) Old 08-08-2007, 09:37 AM
Main Motorcycle: Well, Duh!
MickMaguire's Avatar
G
Ditto on all that.Cutting it off is really the best solution. In all likelihood you will have damaged the thread on the peg too.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
MickMaguire is offline
post #5 of 14 (permalink) Old 08-08-2007, 12:02 PM
Main Motorcycle: Bonneville T100 2007
Suppards's Avatar
Other Motorcycle: Thunderbird LT 2016
I'd use a Dremel too, but I wouldn't cut all the way through the nut. Cut just deep enough to avoid the bolt thread. If the nut is hard against another surface just cut it on a diagonal. Then you'll usually find that the application of a pair of mole grips will spin the thing off, leaving the bolt unharmed.
Seized nuts can be quite a pain can't they? (This is probably a pathetic pun that only English guys will understand!)
Suppards is offline
post #6 of 14 (permalink) Old 08-08-2007, 12:44 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
Once you get it fixed, buy yourself a set of open/closed end wrenches where the closed end is hinged and has a ratchet drive. I use one (12mm) when removing and replacing the footpegs, and it makes it really easy, since you can work around the shocks. The ones I purchased were from Sears, and are called Flex Gear Wrenches. There's nicer ones, but these work for me.
For removal of the stripped nut, I'd give it a shot with a set of Vice Grips first, maybe soaking the threads with WD40 or a commercial rust dissolver (cannot think of the name of the stuff). If that doesn't work, go to the next step, cutting it off, as the others have outlined. Unless it's really rusted, those nuts aren't torqued that high.
The footpegs themselves are 'pinned' to their sideplates, and won't rotate until the nut has been loosened 4-5 turns, so that's some help when you're attempting to get the stripped nut off.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #7 of 14 (permalink) Old 08-08-2007, 05:00 PM
Legend
Main Motorcycle: Tiger 955i
Administrator
Haggis's Avatar
Other Motorcycle: Sprint RS
Extra Motorcycle: Honda XL250
Stripped nut
Did you have an waxing accident at the beauty parlor?
Haggis is offline
post #8 of 14 (permalink) Old 08-08-2007, 06:32 PM Thread Starter
itcha's Avatar
Ha ha ouch!!!!!!
Thanks for the advise, I've tried the vice grips and soaking it in WD40 etc, I guess I go with the dremmel. Time to go to the hardware store and buy one.
Cheers.
itcha is offline
post #9 of 14 (permalink) Old 08-09-2007, 06:36 AM
they may have the nutcracker tool at Pep boys or similiar places.
Good luck bro
G
Geoff is offline
post #10 of 14 (permalink) Old 08-09-2007, 09:31 AM
Quick question - do you mean stripped or rounded?
Stripped meaning the thread is stripped and the nut just spins and wont come off
Rounded means you have mashed up the nut so a wrench or socket just slips off
If it s the former you will have to cut the nut off and deal with likely damaged threads on the peg. If tis the latter then vise grips and or cutting or even one of those (get a rounded nut off) sockets will likely work.
Mick...
Stripped Screw randm Air Cooled Twins Technical Talk 4 08-27-2007 07:33 PM
Stripped threads Colonel_Dorkus Air Cooled Twins Technical Talk 10 07-28-2007 08:55 AM
Stripped out the nut on the fender montana Air Cooled Twins Technical Talk 6 02-15-2007 08:56 AM
I think I stripped the bar-end nut inside my handlebars... Catamount Speed Triple Forum 5 10-30-2006 09:08 AM
stripped head Classic, Vintage & Veteran 4 01-17-2005 07:58 PM
