Tips on Bonneville Bar Position and Grips - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 12-09-2012, 08:51 PM Thread Starter
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
2013 Mag Wheel
Took the Bonnie for her first good run today. I need to change either the bars or the position of the current bars as well as the grips. My arms are long and I find my elbows being bent gets a little uncomfortable. Should I just loosen up the bars and push em forward or would replacing the bars with a slightly lower profile be better, or both?
How do I loosen the bar mounts? Took a quick peak and couldn't see what kind of tool to use.
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline
post #2 of 17 (permalink) Old 12-09-2012, 10:10 PM
Main Motorcycle: T100
Allroads's Avatar
Hi. So the bar mounts with two clamps in the center section. The clamps are attached with 6mm allen head bolts. These come covered with small chrome, plastice plugs. These can be removed with a small screwdriver or a thin blade. You can then loosen the bolts and rotate your bars. You may also need to adjust your mirrors and levers a bit depending on how much you rotate them. These are 5mm allens.
Allroads is offline
post #3 of 17 (permalink) Old 12-09-2012, 10:26 PM
Main Motorcycle: 2011 Triumph Tiger SE
Other Motorcycle: 2012 Triump Bonneville SE
There is a great bonneville bar thread on the forum here:
http://www.triumphrat.net/twins-tech...ar-thread.html
I did a bunch of reading and checked out the pictures and ended up going with the Norman Hyde M Bars. Been riding with them a few weeks and they seem a little bit too low and leaned forward for me. Might put in a riser or might try superbars which appear to be a compromise in between stock and the M bars.
Congrats on the new bike!
Joel
jltriumph is offline
post #4 of 17 (permalink) Old 12-10-2012, 02:13 AM
Main Motorcycle: T120 black
ggfh's Avatar
You mean you want to ride with your arms stretched and locked at the elbow?
ggfh is offline
post #5 of 17 (permalink) Old 12-10-2012, 03:35 AM Thread Starter
Moogs's Avatar
No. Just not pitched at what feels like 90 degrees. Maybe I need to raise em, or pitch em back. Not sure yet. Have to experiment.
Moogs is offline
post #6 of 17 (permalink) Old 12-10-2012, 05:53 AM
ggfh's Avatar
Ok, I see.
You might tilt the a bit forward.
Or change to something else. Is fun to do too.
ggfh is offline
post #7 of 17 (permalink) Old 12-14-2012, 05:56 PM
Main Motorcycle: 2003 Bonnie
DJL415's Avatar
My NH M Bars are on the way! Hope I made the right choice haha!
DJL415 is offline
post #8 of 17 (permalink) Old 12-14-2012, 06:21 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
i used 1" round 1" tall black anodized standoffs from graingers drilled hole to 3/8 used longer bolts, hex fit perfect and cables were good, i do not think much more is possible without some cable changes, good luck enjoy your new ride
rodhotter is offline
post #9 of 17 (permalink) Old 12-14-2012, 06:57 PM
Main Motorcycle: Triumph Street Triple
Johnnystriple's Avatar
Other Motorcycle: 2012 Bonneville Standard
Extra Motorcycle: 2008 Harley Street Glide
I tilted mine up a little because I like my arms a little higher. I sit a little more straight up, which I prefer. Feels a lot like a dirt bike now.
Johnnystriple is offline
post #10 of 17 (permalink) Old 12-15-2012, 05:04 PM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
I use the BellaCorse Superbars. I tried the M Bars, but they created an uncomfortable reach that gave me both back and wrist pain. However, all of us have a little different body geometry...YMMV.
Sheepdog is offline
Tips for Grips DrewDesign007 Air Cooled Twins Technical Talk 18 10-23-2007 10:52 AM
Heated grips switch position - Sprint ST 05+ azicat Sprint Forum 2 05-23-2007 08:21 AM
Tips for grips ecrabbit96 Hinckley Classic Triples 11 02-26-2007 08:16 PM
Any Tips for Replacing Grips? MikeWS1 Sprint Forum 7 04-03-2004 09:29 PM
