Sprocket 19 V 18 tooth - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #21 of 51 (permalink) Old 12-10-2012, 07:38 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
just installed a scootworks BELT DRIVE, said to gear it up a bit, prolly a good thing, just enjoying a clean oiless rear wheel + tire, very nice kit!!!! 18 teeth front 43 rear, also read where belt drives use a little less power a 2.375 to 1
rodhotter is online now
post #22 of 51 (permalink) Old 12-11-2012, 06:00 AM
Main Motorcycle: '16 Triumph T120
Other Motorcycle: '08 Triumph Bonnie T100
Extra Motorcycle: '06 Triumph Scrambler
SprocketCenter.com
Here is another sprocket & chain supplier in the U.S. at least:
http://sprocketcenter.com/index.php/...s/triumph.html
grebmrof is online now
post #23 of 51 (permalink) Old 12-11-2012, 09:33 AM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Originally Posted by biker222 View Post
Here is a great gearing calculator.
Located Here: http://gearingcommander.com/
Thanks for posting this. Many will find it useful. It came in really handy when I went from a 39t to 41t rear sprocket on my Ducati GT1000. The change made the 6th gear usable. There was no detectable change in performance. Since I was now using the 6th gear, there was no change in gas mileage either, which was excellent at an average of 55+.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #24 of 51 (permalink) Old 12-12-2012, 06:00 AM
Main Motorcycle: The one I'm on, mostly.
Originally Posted by rodhotter View Post
just installed a scootworks BELT DRIVE, ... also read where belt drives use a little less power a 2.375 to 1
A drive chain is 98 - 99% efficient at transferring power. A belt drive is a little less.
Regards, Chuck
Charles Lathe is offline
post #25 of 51 (permalink) Old 12-12-2012, 11:11 AM
after reading a lot of info the general conclusion is a belt uses less power, but whatever since i installed it for lo maintain, cleanliness and long wear. on my sportster with wire wheels they only get dusty, adj are rare after break in even with the old tech belt, scootworks carbon fiber-kevlar belt thats a few mm wider than a chain, very few, only needs o adjust after break-in 2-4 thousand miles, harley belts usually go 50-100 thousand miles, for me the clean wheel and tire sells it if i only get 50,000 i would buy it again, yes $579 for a belt + sprockets is expensive but comparing several chain + sprocket changes, especially with labor if you do not do it is not a bad option in the long run, on my 70 bonnie i was forever at the high pressure car wash mostly for the rear wheel, but chain lube has improved for sure, the PITA is not for ME i love a clean shiny ride!!!
post #26 of 51 (permalink) Old 10-05-2013, 08:15 PM
Main Motorcycle: 2013 T100
Other Motorcycle: 2005 VN1600 Nomad
Impossible math
Before changing to the 19t, I took note of precise rpm at speed. Now I am truly perplexed. 70mph was 4200rpm and now 70mph is 4200rpm! Math wise I should have seen about a 5% difference, a drop of about 200rpm. I am totally weirded out on this one. I noticed a 19t stamp on the new sprocket, but by God I'm pullin' that cover off and counting them. If I was sent an 18 with a 19 stamp, NewBonneville is going to hear about it!
"Two wheels and a Blue Ridge Pkwy create positive ions":
OSSAMAN is offline
post #27 of 51 (permalink) Old 10-06-2013, 06:21 PM
Main Motorcycle: Boneville SE
VintageSkies's Avatar
Other Motorcycle: Rocket III
Ossaman.. the speedo is not accurate. The speedo drive is in the trans.. not at the wheel. As such if you tooth up or down you wont indicate any differently. It'll only be apparent when keeping up with traffic !
Flying is easy.. You just hurl yourself at the ground and try to miss!
TPUSA 904, 813 cams, Stage 1 head, Billet manifolds, BC ARK, AI removed, Dominators, TBR39R's, TTP tuned
VintageSkies is offline
post #28 of 51 (permalink) Old 10-06-2013, 06:37 PM
Main Motorcycle: 2009 America
RKPope's Avatar
Other Motorcycle: 2002 BMW 1150 RT
I changed to the 19t on my 09 America and am very pleased with the top end speed on the freeway. It did change my speedo and at 70 mph on the speedo I'm actually doing 65 mph.
Pope
U.S. Army RET
09 America
RKPope is offline
post #29 of 51 (permalink) Old 10-06-2013, 08:15 PM
Main Motorcycle: 2010 T-100
maydaymike's Avatar
Other Motorcycle: 2014 HD Street Bob
With the electronic speedo Bonnevilles, (mid-year 2010 and up), you will need to use tune ecu and correct your speedometer reading after a sprocket or rear tire size change. With the 140-80-17 rear tire and a 17 tooth sprocket on my T-100, the speedometer and odometer read about 5% fast compared to my GPS. After the correction, it is within 1/2 of 1% of the GPS. (recent trip to the Dragon Raid was 1001 Triumph miles and 996 Garmin miles... close enough. BTW on my bike 50mph=3000rpm, 80mph=5000rpm.
2010 Triumph Bonneville T100 Black 118K
2014 Harley-Davidson FXDB Street Bob 37k
IBA#58185
The thing is Bob, it's not that I'm lazy, it's that I just don't care.
maydaymike is offline
post #30 of 51 (permalink) Old 10-07-2013, 02:03 PM
Main Motorcycle: '14 Tiger Explorer
Syndacate's Avatar
Other Motorcycle: '13 XL1200C, '85 CB450SCL
Errr, I don't believe you're correct.
If you take a look at the sport-bike community for instance, where going up in the rear is extremely popular, there's whole companies dedicated to patching VSS signals to correct the speedo (ie. speedo-healer). The VSS is in-trans for most sport-bikes too.
Front wheel sensors are only affected by tire diameter changes, not gearing. This is because the front wheel is fully independent, though changing the wheel diameter changes the circumference so 1 revolution is more or less distance. The calibration of the wheel sensor is set up for a particular diameter.
Transmission VSS's are affected by both tire diameter changes AND gearing.
So if what you said is accurate (VSS in trans), then gearing will affect the speed.
Just bought a '13 Sportster 1200C, so won't be buying anything for a bit. Still have a V7 or Bonnie itch, though. Also a bit of a dual sport itch :-P.
Syndacate is offline
Thruxton - 16 tooth or 17 tooth front sprocket? bpbrownengineer Club Cafe' 26 04-21-2016 04:45 PM
19 tooth sprocket sonicboom Air Cooled Twins Technical Talk 25 12-04-2011 10:57 AM
19 tooth sprocket crabby Air Cooled Twins Technical Talk 5 08-28-2009 08:03 PM
18 or 19 tooth sprocket ajf Air Cooled Twins Talk 34 03-31-2007 07:16 PM
