Help needed after Airbox Removal - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 12-02-2012, 08:16 PM Thread Starter
Hi All
Had the Airbox removed and AI done a few days ago by my local dealer who has done a few of these. My bike is a 2009 Bonny T100 EFI with twin Staintune pipes.
On taking it home, I found the difference noticeable immediately, however when approaching slow corners or in a roundabout in first gear, if I'm feathering the clutch / throttle the bike starts to stutter and actually stalled for a millisecond a few times which was quite disconcerting as I was leaned over at the time.
I took it back and they didn't feel anything was wrong but tried a different map. The same problem exists and now the bike backfires a lot and if after a high rev in 3rd or 4th it backfires and then rocks backwards and forwards on the way down.
When it is idling, it sounds OK however every 4 - 5 seconds it seems to drop a rev if that makes sense. There is also a loud 'tock' sound from around the cam covers too in the same time pattern.
Before I take it back to the shop (who are very helpful BTW) I wondered if there is anything I should advise them to consider?
HeezaGeeza is offline
post #2 of 5 (permalink) Old 12-02-2012, 09:47 PM
Main Motorcycle: 2014 TBird
scottslob's Avatar
Other Motorcycle: 2014 Fxdx, wifeys
The tock noise is most likely the pump for the AI. they dont remove the pump. and now that the hoses have been disconnected, you will hear the noise from it. have you checked your Idle speed? I had similar problems after my dealer did the same surgery on my bike. I brought up the idle just a teeny bit and problem solved.
Friend of Bill's
scottslob is offline
post #3 of 5 (permalink) Old 12-03-2012, 12:44 AM
Main Motorcycle: Black T100
fliplid's Avatar
The "tock" will be the AI solenoid. I ditched all the rest of the system on my bike, and need to get round to bluffing the electronics with a resistor or getting a windoze laptop!
Sent from my GT-S5670 using Motorcycle.com App
From the outside of the asylum.
fliplid is offline
post #4 of 5 (permalink) Old 12-03-2012, 01:00 AM
Forchetto's Avatar
If the shop only had the Factory's alternative tune maps available to them they'll be far too lean with airbox removal and aftermarket pipes. The bike will never run right or develop the increased performance that airbox removal promises.
Factory maps don't contemplate airbox removal at all, as they certainly don't approve of that, they just do alternative exhaust systems like Arrows or similar.
I would strongly advise to get it re-mapped with one of TTP's maps:
You can either send them your ECU for mapping:
http://www.triumphtwinpower.com/efi-...ad-service.php
Or do it yourself using software like TuneECU and one of TTP's downloadable maps like these with the further advantage of being able to remove the solenoid using that same software and disabling the AI for good, doing away with the ticking noise:
http://www.triumphtwinpower.com/triu...-efi-tunes.php
I did a write-up about it here:
http://www.triumphrat.net/twins-tech...win-power.html
Forchetto is offline
post #5 of 5 (permalink) Old 12-03-2012, 02:37 PM
Main Motorcycle: 2012 Tiger 800
TX1911fan's Avatar
It is incredibly easy to use TuneECU and do it yourself. I did it so I know anyone can.
TX1911fan is offline
Just my predators, airbox removal and air intake removal, but no instructions! sbpark Club Cafe' 11 10-16-2012 12:47 PM
airbox removal - jack bike way up to get airbox out? Thruxo Air Cooled Twins Technical Talk 2 04-07-2012 06:12 PM
Triumph Scrambler,Exhaust/Airbox removal info needed rush123 Air Cooled Twins Talk 0 05-13-2008 04:48 PM
Spring Mods--Predators, Airbox Removal, AI Removal idaho_thrux Air Cooled Twins Talk 6 04-09-2006 04:30 PM
