Best After Market Seat Option - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 22 (permalink) Old 12-03-2012, 12:42 PM
Main Motorcycle: 05 T100
Or you could save some bucks and get an airhawk !
chefbobvmr is offline
post #12 of 22 (permalink) Old 12-03-2012, 01:08 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
+1 more for any gel seat. I like the vintage look, so I got a very fairly priced (even new from dealer) $225 Scrammie gel seat. I don't know if weight comes into play with comfort level (doesn't seem to) but I'm only 130 lbs.
Strictly for comfort, the King/Queen is very comfy. My bike had one when I bought it. Just my opinion, but I couldn't get that thing off fast enough. Looks-wise, it leaves much to be desired.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #13 of 22 (permalink) Old 12-03-2012, 01:11 PM
Main Motorcycle: 2012 Bonneville Mag Wheel
Papa Weeley's Avatar
Other Motorcycle: 2013 Honda CB1100
Originally Posted by ff73148 View Post
Never had a K&Q but my Burton keeps me comfortable all day.
Ditto - I can't believe how comfortable mine is, but unfortunately, buying one new probably won't fit a slim budget.
Also, run a search on this question; this has already been discussed at great length here, with lots of great info.
The strong survive, but the courageous Triumph.”
Michael Scott, "The Warlock"
Papa Weeley is offline
post #14 of 22 (permalink) Old 12-03-2012, 02:04 PM
Main Motorcycle: 2012 Bonneville Black
Extra Motorcycle: 2015 Ducati Diavel
If you rarely ride 2 up, I would definitely suggest the Triumph Solo Seat (no rack). I've had it on since day 1 and never seem to get uncomfortable on it (longest ride was about 3 hours). It also helps that it gives you a lot of room in the back to change your riding position. Switching back to the factory seat when I go 2 up only makes me love the Solo more.
Stripleville is offline
post #15 of 22 (permalink) Old 12-03-2012, 06:16 PM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
I use the Triumph Solo Seat...not the one with the rack, but the cafe-styled one. Its a little lower than the the stock "ironing-board" saddle and uses a much better quality foam ( it doesn't bunch up). Available from Hermy's for $243...
http://www.motorcyclestore.us/triump...nneville-t100/
Sheepdog is offline
post #16 of 22 (permalink) Old 12-03-2012, 06:47 PM
Main Motorcycle: vespa
If you really want a perfect seat , one that is in your ideal comfort zone----- Google "How to make a Motorcycle seat". You use your original seat pan ,so fit is not an issue ,and you use readily available foam from many local retailers. The instructions are very detailed and easy to understand. The resulting seat is perfectly contoured and unquestionably the best seat for YOU ! Should you not want to recover the new seat; just about any upholstery shop can do the job for you at a meager cost.
My avatar has my home made seat pictured. I think it looks professional and it is without question --the most comfortable seat available (should be, I made it to fit ME)-----Triumph aftermarket seats are not exactly plentiful which is what prompted me to attempt this task. Iam almost 70( I did it !) and if you would like close up shots of my seat just let me know---I get questions about where I got it , all the time....................................*with the professional leather upholstery job the cost was about $110.00 total*(vinyl would be less cost)
ID:	57659   Click image for larger version
zippyburgertush is offline
post #17 of 22 (permalink) Old 12-06-2012, 09:13 AM
Main Motorcycle: All of 'em
JohnnyRocket's Avatar
Other Motorcycle: '06 'Busa, '12 FXDWG
Extra Motorcycle: '05 Thrux, '82 CB900F SS
I sent my OEM Thrux seat to be worked by this guy Spencer, http://greatdaytoride.com/Seat_Mod_Pics.php
I had the supracor material installed in the rider portion only since I don't take passengers. I believe it was about $75. Firmer than stock, no change in appearance and can still use the rear cowl. Wish the Corbin had a provision (screw inserts) for attaching the rear cowl as I may have went that route...
Speed, Sex, & Sound!
JohnnyRocket is offline
post #18 of 22 (permalink) Old 12-06-2012, 10:02 PM
Main Motorcycle: '04 Triumph Thruxton
How do you like the feel after having it reworked compared to stock? I've been looking at sending my seat off to have the same thing done, but just really unsure how big the difference will be after a few of these threads.
InvertedB is offline
post #19 of 22 (permalink) Old 12-06-2012, 11:06 PM
Main Motorcycle: 2010 Triumph Bonneville
Depends, and sky's the limit. From gel to custom seats. I loved my Bonnie when I test drive it. But being 6'1" I felt a little cramped. So te dealer let me try out the cafe solo seat. Instantly loved it. The hump on the stock seat pushed me forward and was to low for my long legs. With the solo, I could move around. Lay on the tank, or sit up. Worked wonders for me. As for padding and comfortability, te Bonnie's solo seat trumps any seat I had on my harleys
pyr8willy is offline
post #20 of 22 (permalink) Old 12-07-2012, 02:07 AM
Main Motorcycle: Bonneville
geoffmcmanus's Avatar
Other Motorcycle: Burgman 400
I have been through most options but have eventually capitulated and got a K&Q (hated the looks).
Geoff.
geoffmcmanus is offline
Another Seat Option sliphorn Sprint Forum 0 07-25-2010 08:39 PM
Whos got an After market seat Poddy Sprint Forum 65 06-19-2010 03:43 AM
Sargent seat option? Ken M1 Street Triple Forum 2 04-04-2009 09:17 AM
Can anyone recommend the factory option gel seat? bumblebee Tiger Mods & Bolt-Ons (archive) 8 11-01-2007 11:11 AM
After market seat for 07 Sprint ST? Max_NYC Sprint Forum 12 12-27-2006 05:25 PM
