Bonneville / Thruxton front height difference? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-28-2012, 09:54 AM Thread Starter
Main Motorcycle: 2012 Bonneville
Hey all
I was wondering if there is a difference between the front height of the Bonneville and the Thruxton? And is the Thruxton length rear shocks a direct bolt on to the Bonneville?
garyy115 is offline
post #2 of 12 (permalink) Old 11-28-2012, 11:29 AM
Don't know about the first question but my guess is that the Thruxton is slightly lower due to 18" fron wheel. The rear shocks can and often are changed for a taller seat height and more likely slightly sharper steering. I did it to my 2004 T100 and I'm very pleased with the result on both counts.
Scooter Paul is offline
post #3 of 12 (permalink) Old 11-28-2012, 11:54 AM Thread Starter
Which brand of Shocks did you go for?
Im currently looking at either Ikon's or Hagon's. Im only looking to cruise around the city. Which would you prefer?
garyy115 is offline
post #4 of 12 (permalink) Old 11-28-2012, 12:10 PM
I'm really not going to say! I bought a set of shocks from a company that has had a lot of negative comments on here due to their alleged rip off of other firms products. I had a standard length set of Ikon adjustables before the change and with my type of riding (relaxed) I would say no need to pay for premium brands. Why not try and get a set of take off Thruxton originals? If you want the looks of the premium brands all I can say is there's plenty out there and some look more 'racey' than others.
post #5 of 12 (permalink) Old 11-29-2012, 12:01 AM
Main Motorcycle: Bonneville 09
Other Motorcycle: K1300S
Extra Motorcycle: WR250R
I've been thinking about doing the same thing on my '09 mag wheel Bonny. The Thruxton shocks are indeed longer, but since the shocks are mounted at an angle, the delta doesn't translate into a equal increase in seat height. Still, it should be a noticeable increase.
Streetzilla is offline
post #6 of 12 (permalink) Old 11-29-2012, 01:04 AM
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
Originally Posted by garyy115 View Post
Hey all
Depends on the Bonnie. The standard or SE rides a 17" wheel, the T100 rides a 19" front.
I believe the rear shocks are 360mm on a Thruxton to a 340mm rear on a Bonneville T100. I plan on putting in an aftermarket 360mm rear shocks on the bonnie when I get it, to lift it up a tad. I'm 6' 2". The parts between the two should be interchangeable.
I hear good things of the Ikon or Koni shocks for the price:
http://www.triumphrat.net/twins-talk...on-shocks.html
You should probably do both fork springs and shocks.
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline
post #7 of 12 (permalink) Old 11-29-2012, 07:24 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
base + se shocks are 330mm for the 2012,s if you want some comfortable shocks get the bitubo's, just put the midgrade ones on WOW what a nice ride, i am 170lb that is in their base setup, the springs actually flex when i bounce on the seat, very quality as well about $450 in the usa
rodhotter is offline
post #8 of 12 (permalink) Old 11-29-2012, 11:10 PM
Main Motorcycle: 2007 Bonneville
El Moderatore
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
1/2 and inch height difference and yes the shocks just bolt on. You are talking about two exactly the same swing arms, engines and frames. Everything else is just bolt on differences.
Calliway is offline
post #9 of 12 (permalink) Old 11-29-2012, 11:59 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
I agree with this thought, being that they are at an angle. But from my experience, the ride difference was actually exaggerated. Being the runt that I am, I dropped to a 310 mm (-1.2") rear. The space between the rear wheel and fender nearly disappeared. I don't know if this is because of the geometry of the spring angle vs. angle of movement of spring arm, or just my imagination. I just know the visual difference was much more than I had anticipated. The ride height for me was also effected more than expected, which was a nice surprise.
Long story short (too late), try playing with different heights. You may find a happy spot much easier than you realize.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #10 of 12 (permalink) Old 11-30-2012, 06:00 PM
DezynGuy's Avatar
Other Motorcycle: 2007 Tiger
I, too, am going a tad longer...I'm only 6' tall, but am looking at the Hagon 2810's (+10mm), with black coils.
"I live for myself and I answer to nobody." -- Steve McQueen
DezynGuy is offline
Renntec rack, different part numbers for Bonneville and Thruxton, difference? jet987 Air Cooled Twins Talk 4 10-26-2012 11:05 AM
Why the seat height difference in Bonnevilles Harry Baules Air Cooled Twins Talk 5 05-09-2011 08:22 AM
What's the difference between the Modern Bonneville , Thruxton and Scrambler Tank? SST Air Cooled Twins Technical Talk 3 07-26-2010 11:28 AM
T100 vs: SE height difference jon_l Air Cooled Twins Talk 15 03-01-2010 07:38 PM
Bonneville?Thruxton Front Fender Swap Brooksie Air Cooled Twins Talk 14 07-27-2005 11:44 AM
