idiot light screw up - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 11-27-2012, 11:07 AM Thread Starter
Main Motorcycle: any
Other Motorcycle: H-D
Extra Motorcycle: Bonnie
Hi,
When trying to switch to LED idiot lights the neutral light boot just crumbled apart. I think that when I was trying to put it back together I shorted out the neutral light switch. The only way that the bike will now start is with the side stand up and the clutch pulled in. My guess is that I might have blown the diode pack. When I looked on a site for a replacement back I saw four wires red,white,black and yellow. as I look at the wiring diagram I see only three wires. Am I barking up the wrong tree here? Any help would be appreciated.
craigc1947 is offline
post #2 of 3 (permalink) Old 11-29-2012, 08:40 PM Thread Starter
Bump,
A picture is worth a thousand words, so is this the diode pack that is in the starting circuit with the kick stand/clutch switch? :
http://www.ebay.com/itm/03-Triumph-T...item1e747afd58
I've measured the voltage at the neutral light at .25 volts.
post #3 of 3 (permalink) Old 11-30-2012, 12:05 AM
Forchetto's Avatar
That's the carburettor heater thermostat.
The diode pack is buried inside the wiring loom under the tank, close to the optional auxiliary power connector plug.
There's this thread about it and some means of testing it. Photos of it on post number 34:
http://www.triumphrat.net/twins-tech...iode-pack.html
Forchetto is offline
Turn signal idiot light not working after LED Turn signal and idiot light upgrade esbowman Air Cooled Twins Technical Talk 21 10-19-2014 01:19 PM
Thruxton 05 idiot light Treuely Air Cooled Twins Technical Talk 1 09-26-2012 02:07 AM
Idiot light is on... No False Enthus Air Cooled Twins Technical Talk 9 07-24-2011 04:25 AM
Oil Idiot Light Problem - Going on and off. Junipero Air Cooled Twins Technical Talk 5 04-25-2011 07:48 PM
EMS Idiot Light ralphus Sprint Forum 1 05-27-2008 05:39 PM
