T-100 Wheels Off Ground - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 11-25-2012, 08:53 PM Thread Starter
Main Motorcycle: 2013 McQueen #68
ArmyVet's Avatar
Gents., Lads, & Lasses,
What is the most affordable way to get my T-100 Bonniville's wheels off the ground for winter storage?
I am not overly mechanically inclined.
Do I need to buy some type of expensive lift, or have one of you folks come up with an ingenious method that doesn't break the bank?
Thank you in advance for all suggestions.
ArmyVet is offline
post #2 of 10 (permalink) Old 11-25-2012, 08:55 PM
Main Motorcycle: 2014 TBird
scottslob's Avatar
Other Motorcycle: 2014 Fxdx, wifeys
why do you want them off the ground? I was under the impression that we just inflate the tires up to like 50 psi and call it good.
Friend of Bill's
scottslob is offline
post #3 of 10 (permalink) Old 11-25-2012, 09:00 PM Thread Starter
ArmyVet's Avatar
Scott,
Not sure. I've heard both. It can get sub zero here for long stretches in January & February. The manual even says to get off the tires if possible.
ArmyVet is offline
post #4 of 10 (permalink) Old 11-25-2012, 10:51 PM
Main Motorcycle: 2017 Triumph T100
foggy95's Avatar
Center stand, plus you'll get the other obvious advantages....
foggy95 is offline
post #5 of 10 (permalink) Old 11-25-2012, 11:30 PM Thread Starter
ArmyVet's Avatar
Will the center stand get both wheels up?
ArmyVet is offline
post #6 of 10 (permalink) Old 11-25-2012, 11:40 PM
Main Motorcycle: 2007 T100
If you put the stand on a 2x6 the rear will be off the ground then you need to cut another block to put under the front of the engine to get the front tire up a bit. Better yet move south so you can just ride year round!
larrykahn is offline
post #7 of 10 (permalink) Old 11-26-2012, 12:48 AM
Main Motorcycle: '17 Thrux R
steve betts's Avatar
Other Motorcycle: '02 Bonnie
If you have a centerstand you can just take a piece of wood, say 6" wide X 12" long X 1/4 to 1/2" thick and tap it underneath the front wheel with a hammer. That's what I do. Many believe this to be overkill but it's quick insurance. If you had somebody securing the bike while you're tappping, you can do the same thing with both wheels using a side stand.
steve betts is online now
post #8 of 10 (permalink) Old 11-26-2012, 08:35 AM
Main Motorcycle: 2007 Bonneville T100
rwantin's Avatar
Other Motorcycle: 2004 BMW R1100S
Extra Motorcycle: 1992 Ducati 900 SS
I have a Norman Hyde centerstand. Of course it unloads the rear wheel but seems to take a fair amount of weight off the front as well. I simply lift the front end a bit (grabbing the wheel) and slide a few sheets of cardboard under the tire. Seems to work fine...
Robert
2007 Bonneville T100 tuxedo - Ricor Intiminators, Ohlins 36E's, TOR's, Motodemic LED headlight, Burton DS003 and other geegaws.
rwantin is offline
post #9 of 10 (permalink) Old 11-26-2012, 09:51 AM
Main Motorcycle: My 2009 Bonneville SE
Is there any problem with leaving the suspension completely extended for a long time? I have a m/c jack that I can lock in place with both wheels of the ground but I am concerned about leaving the shocks and forks fully extended for several months in a damp garage. Maybe I could wipe down the shiny bits with some kind of rust preventative. What about the seals? Would extended storage in the fully extended position do them any harm? (No jokes about calling the Dr. after four hours please.)
GArider50 is offline
post #10 of 10 (permalink) Old 11-26-2012, 09:56 AM
Main Motorcycle: 06 bonneville hardtail
o4petesake's Avatar
Other Motorcycle: looking
GArider50
....ya ruined my punch line!
o4petesake is offline
Keeping wheels off ground during winter vector Tiger Chat 16 12-04-2012 06:59 PM
Convert pos ground to neg ground?? enuf Classic, Vintage & Veteran 9 02-10-2012 08:39 AM
Early Trophy wheels verses later 17" wheels esox Trophy 5 12-30-2011 09:31 PM
Positive Ground or Negative Ground? Whiteman Air Cooled Twins Talk 1 10-16-2011 09:42 AM
