Neutral light - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 11-18-2012, 07:32 PM Thread Starter
Main Motorcycle: 2016 Street Triple R
eric nyc's Avatar
Other Motorcycle: 2014 Thruxton
Neutral light
My neutral light has stopped working. A couple weeks it was working sporadically and now it's just not at all. What are the possible causes? Clearly I hope it's something simple like a blown bulb, electrical short, or loose lead. But is there any chance it's a problem down in the gear box? I'm not tearing down and cracking the case just to get an idiot light working, but what's a good diagnostic plan?
eric nyc is offline
post #2 of 4 (permalink) Old 11-18-2012, 09:25 PM
Main Motorcycle: Bonneville se
mr1bienvenu's Avatar
Here is everything you need to know. Enjoy.
http://www.triumphrat.net/twins-tech...ch-boring.html
mr1bienvenu is offline
post #3 of 4 (permalink) Old 11-18-2012, 09:41 PM
Main Motorcycle: Scrambler
Olhogrider's Avatar
Other Motorcycle: Sold
Extra Motorcycle: Gone
I had the same problem on both bikes. It is caused by a loose female spade lug. No that was NOT racist or sexist. That is what the connector is called! You will find it on the bottom of the engine near the oil filter. Pinch it a bit to make it more snug before reinstalling it.
Damned Dirty Biker!
Olhogrider is offline
post #4 of 4 (permalink) Old 11-19-2012, 10:55 AM
They do fail. Mine was leaking a little bit of oil through the switch.
Hints if you have to replace it:
You don't have to drain the oil, although some oil will drip out.
I found it very hard to properly (securely) re-attach the connector because it's so difficult to access in that recess; angled long-nose pliers were helpful.
Buy the Triumph part and use the sealing washer included with it; apparently the thickness of the washer is important.
Marty
Baltobonneville is offline
Neutral light went out, then.... Riven Air Cooled Twins Technical Talk 11 03-29-2011 12:49 AM
Neutral light doubles a Charging light ? NorthernThrux Air Cooled Twins Technical Talk 9 03-23-2011 06:08 PM
neutral light,,,,, born to be mild T3 Sport / Touring Forum 18 10-10-2009 05:32 AM
neutral light zoombass Hinckley Classic Triples 1 05-18-2009 08:24 AM
Neutral light comes and goes..... SpaceCoastRat Air Cooled Twins Technical Talk 6 05-12-2009 04:13 PM
