New Rectifier - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 13 (permalink) Old 11-08-2012, 06:46 PM Thread Starter
Main Motorcycle: 2012 Rocket III Roadster
RickMcCl's Avatar
Other Motorcycle: N/A
New Rectifier
While at my local Triumph dealer on Monday; they noticed that when I revved my engine up a bit, the headlight grew dimmer.
They checked things out for free; and advised that the rectifier was going out.
I ordered a new one (aftermarket; the Triumph one was $400.00 US).
It came in today, and was installed this afternoon.
I'm glad that they noticed/checked out the problem; as I'd sure hate to get stranded somewhere.
I've been using the Bonne quite a bit since I got it; close to 2000 miles since I bought it, with 1000 being in the last month.
Rick
RickMcCl is offline
post #2 of 13 (permalink) Old 11-08-2012, 07:50 PM
Main Motorcycle: Cafe'd Bonneville SE
cashmore1985's Avatar
Send a message via AIM to cashmore1985
I'm curious how one knows the rectifier is dying. I am also curious how long they typically last.
'09 Bonnie SE Blue and White
MODS- Lots of 'em
Host and Producer - Cafe Racer Podcast
www.caferacerpodcast.com
cashmore1985 is offline
post #3 of 13 (permalink) Old 11-09-2012, 01:08 AM
Main Motorcycle: '08 T100
bheezy27403's Avatar
Other Motorcycle: '13 CB 1100
Extra Motorcycle: '75 CB 125s project
Mine has gone bad as well. It's 4 years old. I'm going to get mine through Bike Bandit. I believe they are roughly $103 to replace. Fairly easy to do as well, you just have to get into the headlight bucket. I've been keeping my batt on a trickle charge til I purchase the new rectifier.
bheezy27403 is offline
post #4 of 13 (permalink) Old 11-09-2012, 01:16 AM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
http://www.bellacorse.com/bce005.htm
Better than stock
Sent from my SGH-I747 using Motorcycle.com Free App
killian101 is offline
post #5 of 13 (permalink) Old 11-09-2012, 04:51 AM
Main Motorcycle: 05 T100
On these bikes with the stock RR, the headlight dimming when revving slightly off idle is actually normal. Your original RR may have been fine, but as long as the new one is a MOSFET type, at least you'll have improved the charging system even if it wasn't faulty to begin with. I hope they didn't charge you too much for fitting!
Paul.
Herts. UK
PAAS is offline
post #6 of 13 (permalink) Old 11-09-2012, 10:52 AM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
Hi Rick,
You may want to get away from the stock R/R and move it to a neater location in the process. Here is a link to my rectifier replacement story which also links to info by the forum expert on these matters, DEcosse.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/D9 Dash/520 chain/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline
post #7 of 13 (permalink) Old 11-09-2012, 10:55 AM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
Mine went bad a few years ago. The symptom is the battery was not charging sufficiently - there are planty of threads on the fault finding. I went with after market and mounted it on the battery tray to clean up the front end.
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
post #8 of 13 (permalink) Old 11-09-2012, 01:51 PM
Main Motorcycle: 2006 BONNEVILLE T100
RICHW's Avatar
Other Motorcycle: 1999 TITAN PHOENIX
I did this (post #6) R/R mod and it worked out better than I ever expected...
http://www.triumphrat.net/twins-tech...nder-tank.html
later on (in that same thread) I ended up moving the R/R location... it's all good.
please keep your distance
• 26 B0NNEVILLE T1
my garage pics and specs
RICHW is offline
post #9 of 13 (permalink) Old 11-11-2012, 04:16 AM
Main Motorcycle: Standard 2007 Bonneville
conchscooter's Avatar
Mine died when the Bonneville was nearly five years old and had 69,00 miles on the clock. I decided to change the original battery as a preventive to avoid a roadside failure and in so doing may have caused the rectum-fryer to die. I noticed a slight hesitation starting for a couple of days (which I brilliantly ignored) and while stopped at the side of the road to put on waterproofs during my commute the bike declined to start. Just like that. Bumping did not start the bike but I had no slope to help me.
I will replace this aftermarket rectifier in another four years as its cheap and easy and they do seem to die.
conchscooter is offline
post #10 of 13 (permalink) Old 11-12-2012, 10:21 AM
Originally Posted by Aussiematt View Post
Mine went bad a few years ago. The symptom is the battery was not charging sufficiently ...
This was also my experience. It was taking the Battery Tender too long, 3+ hours, to top up the battery.
I decided to be pro-active and replaced it with this, which is the same one that Bella Corse sells:
http://www.ricksmotorsportelectrics....5uZXZpbGxlODAw
It's plug-and-play, smaller and blacker than the original, so it looks a bit better in the original location.
Marty
Baltobonneville is offline
Rectifier. Kintaro Sprint Forum 18 08-15-2012 08:31 PM
rectifier hook up fogcutter Classic, Vintage & Veteran 3 05-23-2010 10:28 PM
REGULATOR-RECTIFIER darkwing7 Sprint Forum 0 04-06-2010 12:40 AM
regulator rectifier help evalu8or Air Cooled Twins Technical Talk 15 07-10-2009 10:03 PM
Rectifier Blownfuse Classic, Vintage & Veteran 10 10-04-2005 03:20 PM
