Carbs VS FI....Opinions? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 93 (permalink) Old 11-01-2012, 02:33 AM Thread Starter
Main Motorcycle: 05 Bonnie
guzzi's Avatar
Other Motorcycle: Honda Helix
Extra Motorcycle: 2001 Bonneville
Hello all. I've been gone from the forum for a long time. Now looking for a new- to- me bike. I had a 2001 Bonnie in the past, sold it when I was ill from some medical treatments. Now I'm back, looking for a fun standard bike that will eventually become a sidecar tug. Sportster, Bonnie, CB750, etc..
I'm wondering if you long time owners think Fuel Injection is better than carbs , (specifically on the Bonnie). I'm fairly familiar with the carb models, the AI removal, etc. But I've been gone whilst the FI came out. Has it been working out without much tinkering? Special tools or equipment needed to keep it in proper nick? is there a common problem to look for while I shop for a Bonnie? The naked eye shows some good looking tubeless rims since my departure, but not much else besides the FI. I guess if the FI is not a wonderful improvement, I'll stick to what I know and save a few grand....
If this has been discussed before, forgive me and post a link to that discussion. Thanks in advance !! Shorty
shorty
[img][/img]
guzzi is offline
post #2 of 93 (permalink) Old 11-01-2012, 10:59 AM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
I have had carbs on bikes that I have owned since the late 60's. Now I have a 2012 T100 with EFI. Love it. Given a choice, I would go with EFI every time.
norton74 is offline
post #3 of 93 (permalink) Old 11-01-2012, 11:12 AM
richm's Avatar
I'll second norton74's comments. The difference between EFI and carbs is just that. With either bike you need to tweak it to run really well (remove AI, snorkel, remove baffle or entire air box, pipes........ how ever far you want to go). Difference is that while you re-jet with a carb'd bike, you simply reprogram the ECU for EFI. With TuneECU and the excellent tunes available from TTP, there's nothing to fear about EFI.
Get the bike you get the best deal on and enjoy......
richm is offline
post #4 of 93 (permalink) Old 11-01-2012, 11:13 AM
Main Motorcycle: 2012 Thruxton 900 Bianca
WindTherapy's Avatar
i'll tell you a couple things i've noticed.
My 2012 EFI Thruxton needs a little help to stay started when it's cold. That's probably due more to the fact that i need a proper tune than anything else. My brother's Carb'd 08 thruxton starts up and stays running easier. However, given the proper tune i'm sure that'd go away. The tune i need is $140 therefore i just haven't done it yet.
The down side i see to my brother's Carb'd bike is that about once a year he takes it to get the carbs professionally sync'd. When we go anywhere above about 2500 ft in elevation he has to take a tool with him to adjust the carbs so he can run at high elevations.
Other than those things i think the only advantage carb's have over EFI is the lack of electronics, and the easier ability to adjust to doing big bore modifications. I hear that if you want to do either the 988, or larger stroker motors you are best off going with carb's.
Hope that helps.
WindTherapy is offline
post #5 of 93 (permalink) Old 11-01-2012, 11:15 AM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
This has been extensively debated in previous threads.
Carbs gives you more options to upgrade (FCR/CR replacement carbs etc) if you want to increase HP. I prefer carbs because I have gone down this route and have the tools, garage and know how to fiddle. For those less willing to work on their bikes I would stay with the newer EFI. Carb versions are harder to come by now. If you want to buy new EFI is your only option.
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
post #6 of 93 (permalink) Old 11-01-2012, 11:17 AM
Main Motorcycle: Bonneville Cofféracer
oopo's Avatar
I got one of the earliest FI (2008) and it seem like you get a bit more power, no worries at different altitudes and you never need to do anything except if you change parts.
Only problem I had was last season when some small hoses had gone bad and some sensors got false air which messed with the air/fuel mixture.. Easy fix though. And the reason why they went bad could be because I messed with them my self..
2008 865cc efi Bonneville. No AI. No airbox. Predators and custom map. 70 rwhp 81 Nm.
oopo is offline
post #7 of 93 (permalink) Old 11-01-2012, 11:19 AM
efi is nice for tuning and such, but when the parts go obsolete, thats all for it. I work on industrial electronics, and much of the stuff from just 5 years ago is now obsolete and there arent any more parts. not all, but some parts are now gone forever.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline
post #8 of 93 (permalink) Old 11-01-2012, 11:19 AM
Main Motorcycle: 2010 Bonneville T-100
Ropeferry's Avatar
Other Motorcycle: 2005 Bonniville 904
I've put 60,000 km on my EFI 2010 T-100. Total joy, trouble free.
I just bought a second bike: 2005 T-100. Hopefully the carbs will be something that I'll come to enjoy.
"I knew that topless lady had something up her sleeve,"
John Prine
Ropeferry is offline
post #9 of 93 (permalink) Old 11-01-2012, 11:30 AM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
The FI bikes require close attention to proper battery voltage to ensure sensor health. A Battery Tender is a good idea for keeping your power source within its prescribed range.
Sheepdog is offline
post #10 of 93 (permalink) Old 11-01-2012, 11:36 AM
richm's Avatar
What electronics are you talking about? Yes, an EFI bike has an ECU, but carb'd bikes still rely on an electronic igniter - so your obsolete argument would apply to both. I remember this exact same argument when bikes first started adopting electronic ignition and there are still plenty of bikes from the '70's on the road. This is certainly not something I'm concerned about.
cliff
richm is offline
Changing monoblocs carbs for concentric carbs pre unit Thruxton Classic, Vintage & Veteran 10 02-07-2014 02:11 AM
want opinions bri Speed Triple Forum 19 05-21-2011 05:48 PM
Looking to buy... Opinions? Nimec2320 Air Cooled Twins Technical Talk 5 12-27-2006 12:10 AM
01 - 04 S3 Opinions scgstuff Speed Triple Forum 38 12-12-2006 10:00 PM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 02:07 AM
