compression ratio - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 67 (permalink) Old 10-21-2012, 12:59 PM Thread Starter
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
compression ratio
reading in my service manual for the 2012 bonnie's it SAYS compression ratio in models with electronic speedometer is 10.2, is this correct? i believe my 2012 bonneville has electronic speedometer from prior readings. with triumph lower fuel requirements other aspects such as timing advance or cam shaft etc is prolly altered to control final cylinder pressure which is the bottom line pretty much to control knock. input appreciated since its my first bonnie since 1970!!! i am in the USA, do models differ over the pond, excepting emmissions of course
rodhotter is online now
post #2 of 67 (permalink) Old 10-21-2012, 01:37 PM
Main Motorcycle: 2006 Bonneville T100
road dog's Avatar
Other Motorcycle: 2002 ThunderBird 900
Extra Motorcycle: 1982 CB900F SuperSport
Compression ration of 10.2:1 sounded too high to me... so I looked it up online. A ratio of 9.2:1 is what I found on several sights. This sounds about right. I have to assume you manual is incorrect.
road dog is offline
post #3 of 67 (permalink) Old 10-21-2012, 01:48 PM
Main Motorcycle: Scrambler
Other Motorcycle: Sprint GT
My Haynes manual also says 9.2:1.
potato_peeler is offline
post #4 of 67 (permalink) Old 10-21-2012, 03:31 PM
Main Motorcycle: Bonneville SE
Models with cable driven speedometer 9.2:1, model with electronic speedometer 10.2:1.
This from a genuine Triumph manual.
Regards
Jim
jimdunleavy is offline
post #5 of 67 (permalink) Old 10-21-2012, 03:41 PM
Forchetto's Avatar
Yes, I've read that. A consequence of the raised CR is an increase in power and torque and the service manual does state that power output has increased from 66.1 PS at 7500 rpm to 68.1 PS at 7400 rpm. That's some 3% which is consistent with raising the CR by 1 whole unit.
Forchetto is online now
post #6 of 67 (permalink) Old 10-21-2012, 03:53 PM
road dog's Avatar
So how did they accomplish the increase? What's the difference in the two motors? Please enlighten us... I'm confused.
road dog is offline
post #7 of 67 (permalink) Old 10-21-2012, 04:02 PM
Forchetto's Avatar
I've looked at parts sites and compared part numbers of the components that could affect the CR. The cylinder head, barrels, gaskets, etc have remained unchanged. The pistons, however, have changed at the same time as the changeover to electronic instruments. This was from VIN number 436004 (for the alloy-wheeled models).
post #8 of 67 (permalink) Old 10-21-2012, 04:13 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
The oldlder 865 motors the pistons are dished on top.So if they rased it they would have to of changed that .Iwould like to see the new piston to get 10.2 I would think they would have to have a small dome on top.The aftermaket hc pistons are around 10.8to 1 and they have a big dome.
mikeinva is online now
post #9 of 67 (permalink) Old 10-21-2012, 04:27 PM
road dog's Avatar
I'm surprised they made a change of pistons... not saying I don't believe it, just shocked that Triumph actually made such a change. I know very little about the specifics of engine internal workings, but wouldn't a 10.9% increase in compression make considerably more increase in horsepower output? (I do know a little about math. )
Did they also change cams, or something else at the same time? And what was the reasoning behind the change(s)? Still confused.
road dog is offline
post #10 of 67 (permalink) Old 10-21-2012, 05:02 PM
Forchetto's Avatar
The camshafts part numbers have remained the same.
Apparently there are other factors that influence how much power you get from a given CR increase. I've read somewhere that 3% increase in power per unit of CR increase is a rule of thumb, consistent, of course, with the right fuel grade being available and possibly the right ignition timing.
This site has a chart halfway down the page giving examples:
http://www.popularhotrodding.com/tec...h/viewall.html
Compression ratio difference? maydaymike Air Cooled Twins Technical Talk 8 05-09-2011 02:32 PM
Compression ratio bias Classic, Vintage & Veteran 12 05-12-2009 02:24 AM
Compression ratio, CR heronhead Hinckley Classic Triples 1 04-12-2008 08:55 PM
Compression ratio okiecityflash Classic, Vintage & Veteran 8 05-30-2006 08:11 PM
possible compression ratio deception???? Maintenance & Workshop Talk 2 09-16-2004 07:26 AM
