2012 Bonnie Indicator Flasher Unit - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 21 (permalink) Old 08-09-2012, 04:56 PM
Main Motorcycle: 2012 Bonneville Mag Wheel
Pauljp's Avatar
Other Motorcycle: 2014 Victory Cross Countr
Originally Posted by Forchetto View Post
Don't know. The data comes from the horses mouth. Both those changes, the relay and the location of the Allen key were announced in Triumph's Tecnical News number TN131 in January 2012.
Note that the VIN numbers the Factory refers to are just the last 6 figures, like this:
SMTTJ9107G9403639
I see, so since my VIN is 51xxxx it is below the number where they switched to 2 pin flashers, that explains why mine is still the 3 pin model. Interesting.
Pauljp is offline
post #12 of 21 (permalink) Old 08-09-2012, 05:34 PM Thread Starter
Main Motorcycle: T'bird
triumphrat.net Vendor
jaguartvr's Avatar
Other Motorcycle: wide glide
Extra Motorcycle: T140v
The one I have is a 2 pin.
I need to find something considerably cheaper than $109 + shipping to the UK. It wiould makr my FEK's far too expensive and I do want to continue offering a plug'n'play item.
WWW.RetroCafeRacer.com
Solo Seats, Fender Eliminator kits, Custom Fenders and much more.
jaguartvr is offline
post #13 of 21 (permalink) Old 08-09-2012, 07:46 PM
Main Motorcycle: 2012 Thruxton
sbabyak's Avatar
Other Motorcycle: FeltVintageIronCross400
Can you post a link to the $109 unit you are referring to? I'm happy to help in the search and I'm curious to know what you're looking at.
This isn't as tidy as a pure swap for the existing relay, but looks like an easy enough unit to install.
http://signaldynamics.com/index.php?...mart&Itemid=77
If I understand it correctly, it will address the symptom of unequal flashers.
sbabyak is offline
post #14 of 21 (permalink) Old 08-10-2012, 02:00 AM Thread Starter
jaguartvr's Avatar
Sorry, it was the signal canceller that you posted a link to that I was refering to..
The link in this post is just what I'm looking for, Thanks
post #15 of 21 (permalink) Old 08-10-2012, 06:43 PM
sbabyak's Avatar
Excellent, hope it works out!
Sent from my Motorcycle iPhone app
'12 Thruxton, de-baffled, de-snorkeled, AI removed, O2 disabled, DNA filter, TTP Breathe, TTP tune #3, Dominator Sports, Cibie Headlight, Hagon Nitros
My Garage
sbabyak is offline
post #16 of 21 (permalink) Old 11-17-2012, 11:53 AM
Main Motorcycle: Tiger 800
Other Motorcycle: Bonneville T120
For those with the 2012+ models with 2-pin denso plug. The SM-3S apears to be the answer if you are looking for a self cancelling relay. I just ordered on and will post results
https://www.kisantech.com/view_produ...?product=SM-3S
TampaJim is offline
post #17 of 21 (permalink) Old 11-17-2012, 06:39 PM
Main Motorcycle: None at this time
Here is LED Flasher
I found this LED Flasher, it might do the trick. Located at this site: http://www.cyclegear.com/eng/product...lay/web1006869
biker222 is offline
post #18 of 21 (permalink) Old 10-12-2013, 01:45 AM
Main Motorcycle: Triumph Scrambler 2012
gglo's Avatar
Other Motorcycle: Suzuki RM250
I have seen links to some aftermarket relays for as little as nine bucks, but I want to hunt down a plug and play direct replacement for the stock unit which works with LEDs. Since it was pointed out that this is a common motorcycle relay they must be out there. I have found nothing yet.
-gglo
gglo is offline
post #19 of 21 (permalink) Old 10-12-2013, 04:46 AM
Forchetto's Avatar
-gglo
There are lots out there. You have to search for something like "Bonneville 2-pin LED flasher relay". These sort of results come out:
Here's an $8.95 exampole:
http://www.superbrightleds.com/morei...c-flasher/787/
Here's exactly the same one but costing $19.95...!
http://www.cyclegear.com/CycleGear/A.../p/34262_37823
Forchetto is offline
post #20 of 21 (permalink) Old 10-12-2013, 10:59 AM
gglo's Avatar
That is the one. I am fighting my urge to have a perfect plug and play, but for now I ordered one to confirm it works and see if I can make a nice simple seat for the relay. There is not a lot of room under the side cover to fasten it down.
-gglo
gglo is offline
Indicator Problem (Flasher Unit?) T140V Dave W Classic, Vintage & Veteran 12 09-14-2010 02:55 PM
where is the flasher unit bass-33 Air Cooled Twins Technical Talk 3 07-26-2010 06:21 PM
How do you test the flasher unit Landshark Classic, Vintage & Veteran 8 12-29-2009 12:26 PM
LED Indicators / Flasher Unit Blackjack Air Cooled Twins Technical Talk 1 03-12-2007 09:16 AM
Flasher unit JontyG Speed Triple Forum 3 02-26-2007 01:11 PM
