Scram mods finished-for now - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 25 (permalink) Old 06-17-2012, 08:54 AM Thread Starter
R0B
Main Motorcycle: FJ1200
Other Motorcycle: building a custom bonnie
Extra Motorcycle: Bonnie with a sidecar
I bought my scram at the end of last year, and apart from riding it back from London, it's sat in the garage in bits ever since. I was very unhappy with the factory seat, and then read up on a number of mods on here and decided that I wanted to change some stuff. I am not claiming to have done anything original, but thought you might like a look.
The factory rear shocks went in the parts bin, and Ricor intmidators went in the front end. I ditched the AI after much reading on here and with the help of tuneecu (so thanks for all the info).
I really didn't like the clock/headlight setup, so that came off. I wanted to retain the factory clock, in case I ever want to sell it the mileage will be true. The headlight shell is from an WD BSA with a Lucas rim and Wipac lens. I had to enlarge and drill various holes, and retained the trip. I read about the Reg/Rect being poor quality and have replaced it with a mosfet unit......doesn't sound much, but has taken me a while to get right. Here are the pictures. Rob
ID:	50774   Click image for larger version
ID:	50775   Click image for larger version
ID:	50776   Click image for larger version
ID:	50777   Click image for larger version
ID:	50779   Click image for larger version
ID:	50780   Click image for larger version
R0B is offline
post #2 of 25 (permalink) Old 06-17-2012, 09:01 AM
Main Motorcycle: 1965 TR6SR
rmak's Avatar
Other Motorcycle: 2007 Scrambler
Nice thougtful mods, Rob. I doubt if they will be your last so please keep us updated.
rmak is offline
post #3 of 25 (permalink) Old 07-16-2012, 09:42 AM
Main Motorcycle: 2002 Bonneville
Love the headlight mod, it extends the vintage look; somehow it makes it look faster, probably because of its "sleekness."
mc-bsa is offline
post #4 of 25 (permalink) Old 07-16-2012, 02:27 PM
Main Motorcycle: This week?
Maxacceleration's Avatar
Looks like you retained the stock bars. For me the tips up of the stock bars make for dis-comfort in the wrists/elbows.
Maybe try some classic flat track style bars? They are comfortable.
Other than that observation your bike looks sleeper clean and not over done.
Nice touches!
My Triumph is magic in the wind...
Maxacceleration is offline
post #5 of 25 (permalink) Old 07-17-2012, 05:07 PM Thread Starter
R0B
Thanks for the comments. When I looked at the factory bars I found that they were canted too far forward and up. I flattened them in line with the switchgear and found the riding position much improved. Interestingly, I looked at another scram in a dealers and the handlebars on that were likewise poorly adjusted.
Rob
R0B is offline
post #6 of 25 (permalink) Old 07-18-2012, 10:14 AM
Main Motorcycle: 2006 Scrambler
Other Motorcycle: 1978 Honda CB550
I have a never seen a headlight setup like that.....very nice touch!
millsrogers is offline
post #7 of 25 (permalink) Old 07-18-2012, 10:56 AM
Main Motorcycle: 07 Scrambler
The Reg/rect under the tank is cool, you fab. that mounting bracket?
And the headlight/speedo swap is slick!! Might have to steal that one. Great job.
LAMF is offline
post #8 of 25 (permalink) Old 07-18-2012, 03:31 PM Thread Starter
R0B
Yep, the reg bracket was made out of some 5mmx40mm alloy bar. I had a mate weld it and painted it black. The reg is a MOSFET FH008 (i think)
R0B is offline
post #9 of 25 (permalink) Old 08-24-2012, 07:04 AM
Main Motorcycle: BMW R1200RT
Other Motorcycle: 2002 T100 Centennial
Ohhh... I want to do that headlight mod for sure !!!
gregpinch is offline
post #10 of 25 (permalink) Old 12-09-2012, 10:44 AM Thread Starter
R0B
I've taken the plunge and started some wiring mods today. Having replaced the Rec/Reg I wanted to remove the wiring from the loom, and re-locate the ignition switch to the right hand side using a joker bracket. As the headlight is filled full of wires, I decided to strip out the ignition switch wires and move them back under the tank to make a bit more space. There is a small (green) link wire between the ignition switch wiring and one of the handlebar wiring connectors. I have had to snip it to pull the wiring back, and will have to put a short section of wire in to reconnect this. I am going to use the live and earth from the rec/reg as an auxilliary power supply, so will be fitting a good quality waterproof connector. I'm going to see if I can find some high quality PVC electrical tape to re-wrap the loom, as the last lot I bought, the glue came off the tape when you tried to apply it!!. I'll keep you updated as soon as I have progress.
Rob
ID:	57809   Click image for larger version
R0B is offline
Finished the Winter mods! Puff98TBS Hinckley Classic Triples 15 03-04-2012 09:25 AM
recent mods (nearly finished) nickletooth Air Cooled Twins Talk 12 07-03-2009 10:45 AM
To Scram or not to Scram, that is the question rmak Air Cooled Twins Talk 8 03-04-2008 05:57 PM
Finished my mods- here she is mates Granitsky Air Cooled Twins Technical Talk 25 02-15-2007 03:39 PM
almost finished Airguy68t100r Classic, Vintage & Veteran 8 10-26-2006 01:49 PM
