British Cutoms Turn Signal Review - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 16 (permalink) Old 08-09-2012, 11:41 PM Thread Starter
Forum Liaison
Main Motorcycle: 04 Thruxton
RumRunner's Avatar
Other Motorcycle: 05 Tiger
Originally Posted by open1mind View Post
I have had the same issues described with identical lights from BC. Just bit disturbed that they continue to sell them with this known Problem and a warranty disclaimer on their we page! Has anyone actually found a good non-led replacement? Everyone that I have found looks like the same poor quality!
I "fixed" mine so they no longer break although it was a little rube goldberg... I rewired the socket, and then when I installed the socket into the housing I filled around the base of the wires and socket with silicone RTV. Since doing that I haven't had an issue.
RumRunner is offline
post #12 of 16 (permalink) Old 08-17-2012, 10:18 AM
Main Motorcycle: 2010 thruxton FEK etc
open1mind's Avatar
Other Motorcycle: Victory Hammer, 69 BSA
Extra Motorcycle: 1979 GS 1000e, 86 VFR
While I am glad that you have found a solution, I'm pretty disapppointed that BC continues to sell these things. Additionally, I am too busy to spend my weekend re-engineering (OK- I am just too lazy/inept) the component. Glad that most of you have the time/skills/motivation, but should we really be doing that?
Keeping an eye out for a replacement that I can swap in. I also have this thing installed, and have some misgivings about using an LED light with it, since it will need a load equalizer.
http://www.pcb.me.uk/
open1mind is offline
post #13 of 16 (permalink) Old 09-06-2012, 02:42 PM
open1mind's Avatar
If anyone is interested, I gave up and just had my dealer install these things. They look pretty good, and so far they work well. Amber/Clear looked best.
http://www.roguemotorsportz.com/i126...FUK4tgodwxMA-g
post #14 of 16 (permalink) Old 09-06-2012, 08:33 PM
Main Motorcycle: 2009 Triumph Bonneville
Cruzin1a's Avatar
That's areal bummer to hear about the BC signals. I am dying to get rid of the stock signals and I am having a hard time deciding what to go with.
Cruzin1a is offline
post #15 of 16 (permalink) Old 11-23-2012, 12:28 PM
Cruzin1a's Avatar
I've decided to go with the Maund FEK kit that will include the front and rear signals.
Cruzin1a is offline
post #16 of 16 (permalink) Old 11-23-2012, 01:15 PM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Originally Posted by RumRunner View Post
I must go through more vibration than most with where and how I ride, although I've spoken with a number of guys that have had the same problem.
Doug,
I, too, have gone through multiple housings with the same tab failure on the bulb socket that you've experienced. I currently only have a left front and right rear signal going. Over the past 4 years I've probably bought 10 of these little monsters.
I'll try the silicone fix you came up with. My field repair on these is to wrap the bulb holder with a piece of safety wire & secure it to the housing with the tab screw. Gets the signal working/extends the time it takes for the bulb to rattle itself to death.
Regards,
--Rich
beemerrich is offline
Turn Signal Review gbc Air Cooled Twins Technical Talk 3 09-12-2010 11:49 AM
British-Customs Front Turn Signal Bracket question... ondrej.glembek Air Cooled Twins Technical Talk 4 08-12-2010 03:26 AM
Airbox Mod from British Cutoms on an '06 Scrambler. JVCRN Air Cooled Twins Technical Talk 3 03-22-2010 03:41 AM
British-customs turn signal relocation kit questions... BonnieBlack07 Air Cooled Twins Technical Talk 2 07-29-2008 12:00 PM
