tire pressure - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 04-15-2011, 10:37 AM Thread Starter
Main Motorcycle: 09 Bonneville SE
Kito's Avatar
Other Motorcycle: I wish
tire pressure
Does anyone know why the rear mag wheel pressure is 41 and the spoked wheel is 38? Could you run 38 in the mag wheel without harm? Thanks for your thoughts. Kito.
Kito is offline
post #2 of 17 (permalink) Old 04-15-2011, 10:46 AM
Forchetto's Avatar
The mag wheel tyre is tubeless and radial. Don't know why the pressures are different, but the tyres are. I wouldn't run the mag wheel tyres at any less than the maker recommends. The pressures are decided after prolonged testing and cooperation between the tyre maker and the bike manufacturer.
Forchetto is offline
post #3 of 17 (permalink) Old 04-15-2011, 12:14 PM Thread Starter
Kito's Avatar
Thanks Forchetto. I'm a new member but already I value your advise and look for your posts. Saying that, can you direct me to the post where you have the dimemsions of the bars you installed. Many thanks, Kito.
Kito is offline
post #4 of 17 (permalink) Old 04-15-2011, 03:10 PM
Forchetto's Avatar
The Norman Hyde "M" bars?. Thread here:
http://www.triumphrat.net/twins-tech...eville-se.html
post #5 of 17 (permalink) Old 04-15-2011, 05:54 PM
Main Motorcycle: Triumph T 100 w/sidecar
Other Motorcycle: BMW R1100RT w/EZS sidecar
No matter what cycle, I've always run the highest recommended pressure on the side of the tire. I've always gotten great milage out of my tires. What little traction might be lost because of a slightly smaller contact point isn't noticeable to me, even here in the very rainy great North West US (Oregon).
Karl
jkmolt is offline
post #6 of 17 (permalink) Old 04-15-2011, 07:31 PM
Forchetto's Avatar
The tyres are not made just for our Bonnies. The pressures stated in the manual are for the maximum laden weight our bikes are designed for. If those same tyres are fitted to a lighter or heavier bike they'll require different pressures.
A good example is a relatively light car like my Miata (Mazda MX-5), which only requires 26 psi, whereas the maximum pressure stated on the tyre sidewall is 51 psi...! the same tyres fitted to a heavier car will require more pressure.
Just follow the vehicle makers recommedations. If you feel that a little more pressure improves things, go up something like 10-20% but not up to maximum stated on side wall.
post #7 of 17 (permalink) Old 04-17-2011, 11:02 AM
Main Motorcycle: 2009 Mag Wheel Bonneville
parallelworld's Avatar
Other Motorcycle: After the old Defender!
Agree with Forcetto
I always run the recommended pressure as per the owners handbook and check at least once a month.
per cognoscenti
parallelworld is offline
post #8 of 17 (permalink) Old 04-18-2011, 05:15 PM
If you're riding a T100 with tube tires, they seep air. I check my tires very regularly, at least once a week and usually have to add a pound of air after a week.
Karl
jkmolt is offline
post #9 of 17 (permalink) Old 04-18-2011, 11:12 PM
Main Motorcycle: Standard 2007 Bonneville
conchscooter's Avatar
Ride On takes care of seepage, and for all I know it helps with flats. It's hard to prove a negative.
http://www.ride-on.com/
conchscooter is offline
post #10 of 17 (permalink) Old 04-19-2011, 05:26 AM
+1 I do the same.
Plasma.
plasma is offline
tire pressure pz1 Air Cooled Twins Technical Talk 25 01-14-2008 05:37 PM
Tire pressure? MQracing Daytona Deliberations 8 08-01-2007 09:14 PM
What tire pressure should I run? FelixLeiter Speed Triple Forum 12 01-03-2007 02:50 PM
Tire Pressure Drift Air Cooled Twins Technical Talk 10 12-19-2006 02:05 AM
Tire pressure and mixing tire brands RJScotti Hinckley Classic Triples 6 09-30-2006 03:56 AM
