Bonneville Headlight Replacement - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 60 (permalink) Old 04-08-2011, 05:30 PM Thread Starter
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Was told by Brent of Newbonneville.com that the perfect headlight replacement for the Bonneville is the Sylvania H6024 sealed beam halogen unit.
I bought one but have yet to install it as I was able to clean the fogging off of the reflector and the inside of the lens of my original unit using a soft cloth sprayed with Windex poked through the bulb opening.
I'm going to try both the original unit and the Sylvania to see which has the best performance.
The only problem that I can see with the Sylvania bulb is that the parking light function is lost.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is online now
post #2 of 60 (permalink) Old 04-08-2011, 05:32 PM
Main Motorcycle: mine
And you use the parking light a lot do you ??
boofhead is offline
post #3 of 60 (permalink) Old 04-08-2011, 05:48 PM
Main Motorcycle: '14 Thunderbird Commander
FastFreddieCAN's Avatar
Other Motorcycle: Also like Ducati S2R 1000
Extra Motorcycle: Would like Street Triple
Wider beam
I find the Sylv bulb has a wider beam that covers the road from ditch to ditch.
A proud SWOMP Rat
'14 Thunderbird Commander - no longer stock (that didn't take long...)
FastFreddieCAN is offline
post #4 of 60 (permalink) Old 04-08-2011, 09:11 PM Thread Starter
tsmgguy's Avatar
Have you noticed what low milage, totally original 100th anniversary model Triumph T100 Bonnevilles have been selling for recently? The point is that this admittedly minor and probably less than useful original feature is lost when the stock headlight is replaced.
post #5 of 60 (permalink) Old 04-08-2011, 09:25 PM
Main Motorcycle: '07 Black
Easy13's Avatar
I'm considering the same mod so please keep us informed. Swap on the new one and take a night ride out to Esperanza. That stretch of I 10's beautiful at night...
"Cognito Ergo Wrenchum"
Easy13 is offline
post #6 of 60 (permalink) Old 04-09-2011, 09:12 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Sounds like you need to shelve whatever take offs you have in a box for reinstallation down the road. This is clearly an improvement you can make that is totally reversible...you shouldn't let something like giving up a function that is not used (e.g. parking light) in order to vastly improve a function that you do use.
--Rich
beemerrich is offline
post #7 of 60 (permalink) Old 04-09-2011, 12:31 PM
The "parking light" is useless. I think it's in there to comply with a European safety requirement, just as the side reflectors are there to comply with US requirements.
I unplugged the parking light and stuffed the connector in the headlight shell when I replaced the headlight with a Hella. I saved the parking light and its connector in case I ever want to use the connector to power an accessory, not likely. In any case, I can easily put it back to original, not that I can imagine a reason to do so.
Let us know what you think of the Sylvania. Not everyone likes it.
Marty
Baltobonneville is online now
post #8 of 60 (permalink) Old 04-09-2011, 06:07 PM
Main Motorcycle: 2010 T-100
chris r's Avatar
I tried several different bulbs and found that the real culprit was the cheap plastic stock reflector. Once I installed a Cibie reflector the Sylvania was a good match.
chris r is offline
post #9 of 60 (permalink) Old 04-10-2011, 08:16 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
I'm sure you are correct re the reflector. My T100 came with an H4 bulb, and the headlight was really bad. On the other hand, my W650 also came with an H4 bulb, and the headlight was excellent. I now run a 6024 on the T100. Much better than the stock setup. Do keep in mind that the 6024 is an automobile headlight, and the lens isn't designed to provide more light to the right side of the road (USA) as are lights with lenses specifically designed for motorcycles.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #10 of 60 (permalink) Old 04-10-2011, 09:30 PM
Sylvania 6024XV
I replaced the reflector & bulb with the Sylvania 6024XV sealed beam. I find it sheds more light on the road when I ride with friends that have stock. Yes you loose the parking light, but in Canada it is not required. Small price to pay to get better night vision.
From the site:
"Sylvania XtraVision 65-Watt High Performance Halogen Headlight delivers three times more foreground illumination which is designed to create up to 20% more strong illumination and increasing down road visibility with no added glare. It adds 850 hour of a higher wattage light source which is twice the standard sealed beam. This sealed beam project more uniform beam pattern thereby helps to evident better at night which enhances driving safety. This XtraVision headlight been designed for maximum durability and performance."
Hope this helps
FF
A proud SWOMP Rat
Bonneville T100 headlight replacement BG Bonnie Air Cooled Twins Technical Talk 5 06-03-2013 07:38 PM
headlight replacement com5984 Speed Triple Forum 15 04-12-2011 05:53 AM
Headlight replacement FelixLeiter Speed Triple Forum 19 04-26-2009 12:03 AM
Headlight replacement s4 bunjinbantam Triumph SuperSports 5 09-20-2005 09:49 AM
