Front End Swap - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 20 (permalink) Old 12-06-2010, 09:09 PM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
Originally Posted by nickletooth View Post
re:what have we got here?
it's a daytona 675 front end,i have just sold it actually and the tank.i have decided to build a streettracker now.
Nickletooth, were those 675 forks a straight swap?
Chris / RudeBoy BIR #309
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is online now
post #12 of 20 (permalink) Old 12-07-2010, 12:38 AM
El Moderatore
Main Motorcycle: 2007 Bonneville
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
The F3 has standard forks so they just slip in. When you go to USD forks you need new triple trees and then everything goes out the window.
Calliway is offline
post #13 of 20 (permalink) Old 12-07-2010, 12:54 PM
Main Motorcycle: thruxton
nickletooth's Avatar
Other Motorcycle: electric bike.(project)
no it was not a straight swap but not too complicated either.i did a thread on the swap,search for daytona 675 front end swap and read that ,the pictures may now be deleted tho.
Two pints of lager and a packet of crisps please.
nickletooth is offline
post #14 of 20 (permalink) Old 11-09-2012, 06:59 AM
Main Motorcycle: '05 Bonneville Black
Bhodi513's Avatar
Other Motorcycle: '12 Daytona 675R
Extra Motorcycle: '78 Yamaha SR500
Reviving this thread...
I stumbled across this thread while searching and though I would revive it instead of start a new one.
Has anyone seen a front end swap that retained a spoked front wheel?
AB
Bhodi513 is offline
post #15 of 20 (permalink) Old 11-09-2012, 01:23 PM
I know someone who used F3 forks (41 mm just like ours) and retained his Thruxton lowers therefore retaining his spoked wheels. It can be done.
post #16 of 20 (permalink) Old 11-09-2012, 05:34 PM
Main Motorcycle: 2012 Thruxton
Is there an advantage to doing a front-end swap vs. replacing OEM internals with bitubo/traxxion/ohlins cartridges (besides the $$)? I'd assume that the USD forks would, in theory, be superior to standard forks w/ cartridges but by the time you factor in the custom fab work that has to be done to fit the USD forks, the previously mentioned $$ savings of the front end swap is probably null.
cashman is offline
post #17 of 20 (permalink) Old 11-09-2012, 07:36 PM
Main Motorcycle: Triumph Street Triple
Johnnystriple's Avatar
Other Motorcycle: 2012 Bonneville Standard
Extra Motorcycle: 2008 Harley Street Glide
Is the F3 also a direct swap to a Bonny Std? I sure would like to have duel disc brakes.
Johnnystriple is offline
post #18 of 20 (permalink) Old 11-09-2012, 08:53 PM
Main Motorcycle: Cafe'd Bonneville SE
cashmore1985's Avatar
Send a message via AIM to cashmore1985
I may be wrong on this but if the F3 swaps directly onto a spoke wheel Bonneville, it will not swap directly onto a mag wheel Bonneville. The forks on a mag wheel bike are 1/8" farther apart. The top and bottom yoke would not accept the F3 front end.
'09 Bonnie SE Blue and White
MODS- Lots of 'em
Host and Producer - Cafe Racer Podcast
www.caferacerpodcast.com
cashmore1985 is offline
post #19 of 20 (permalink) Old 11-10-2012, 04:07 AM
I don't see why you couldn't do a straight swap on a standard mag wheeled bonnie if you use the upper and lower trees from the F3.
post #20 of 20 (permalink) Old 11-10-2012, 01:39 PM
I'm sure that is possible. Does anyone know if the bearings and stem length are the same on an F3 as our Bonneville? That and the location of the steering stops on the lower yoke are the only problems I see there. For my money, if I was buying a new front end, to include upper and lower yokes, I would just get a GSXR one. I already have the F3 inner forks in my Bonneville.
MODS- Lots of 'em
GSXR Front End Swap twincam5 Sprint Forum 19 08-06-2008 01:55 PM
Front end swap causeofhim Trophy 1 10-03-2007 05:50 PM
Front end Swap 06thruxton Club Cafe' 28 04-20-2007 01:40 PM
GSXR1k Front End Swap kuhlka Speed Triple Forum 134 01-26-2007 11:11 PM
FRONT END SWAP Sport Sprint Forum 11 11-08-2006 09:07 PM
