Bent Kickstand - foot part - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 07-15-2009, 12:21 PM Thread Starter
In my attempt to cut my 20 minute commute down by at least 10 seconds i drove in between two parking lot curbs instead of going around. I managed to hit the knob on my kickstand - the knob that your foot uses to push the kickstand down. It was good news in the sense that i thought I had hit my muffler and was expecting that I had gouged the crap out of it. Bad news in that it beat the knob in enough that my foot can no longer get a good enough grip on it to push it down.
Does anyone have any suggestions for bending it back into place?
nodlive is offline
post #2 of 7 (permalink) Old 07-15-2009, 12:24 PM
Wrap a shop rag around it and slide a piece of pipe over it. With gentle but steady pressure bend it back out. Be careful, if you get too aggressive, you might snap it off.
'09 Speedy-19t front sprocket, BC Bomber Pipes,
Progressive Front Springs, Centerstand, 2" risers.
Pending-418HD Progressive rear shocks, ARK.
me1.0 is offline
post #3 of 7 (permalink) Old 07-15-2009, 02:39 PM
Main Motorcycle: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
Bending
Don't know if I'd cold bend it, generally speaking when it gets bent in the first place, it stresses and crystallizes the metal which then will break if you try and bend it back.
I'd find a welding shop, see if they can get a torch on it without hitting the bike and heat bend it back. IF not, take it off the bike and do it on the bench...
Just sayin'
Sitting on a cornflake waiting for the van to come!
koifarm is offline
post #4 of 7 (permalink) Old 07-16-2009, 03:09 PM
Main Motorcycle: 2001 Sprint ST (Red)
Other Motorcycle: 2007 T100 Red & Black
Extra Motorcycle: 56 vespa, 03 atlantic etc
Send a message via AIM to coldnight
Lots of people on here have had to cold-bend them down, away from the aftermarket exhaust they just bought, it is pretty soft and most folks get away with doing it with vice-grips or with the pipe bit as suggested above.
coldnight is offline
post #5 of 7 (permalink) Old 07-16-2009, 05:17 PM Thread Starter
Yeah, and its the stand part i need to bend, just the part your toe/heal grabs to push the stand down, so if it broke off it wouldnt be the end of the world.
nodlive is offline
post #6 of 7 (permalink) Old 07-16-2009, 09:27 PM
Send a message via AIM to CAPTDON
Bent
Had to cold bend mine x2 already! Not a problem. Might take 2 people to do tho?
CAPT D
CAPTDON is offline
post #7 of 7 (permalink) Old 07-16-2009, 10:08 PM
JG
Main Motorcycle: 2005 Thruxton
JG's Avatar
Other Motorcycle: 1984 Honda XR350R
I adjusted mine once by heating it with a propane (or maybe it was MAPP - a little hotter) torch right in the spot where I wanted to change the bend. I stuck a small pipe over the ball end knob and part way down the shaft to use for leverage. I heated it until it was starting to glow. Then it was pretty easy to bend. I did it right on the bike, adjusting it a little at a time and checking the operation of the kickstand, until it was bent the way I wanted it. Then just sprayed a little black paint on it, since the original paint was burned away.
JG is offline
kickstand modre Air Cooled Twins Technical Talk 15 12-02-2007 04:47 AM
Kickstand help stealthy1 Daytona Deliberations 1 07-14-2006 07:41 AM
d&d's and kickstand oregonthruxton Club Cafe' 4 01-14-2006 06:32 PM
foot brake lever bent stevebedder Tiger Mods & Bolt-Ons (archive) 5 12-14-2005 06:45 PM
Bent Side Stand / Kickstand Brit_Keith Maintenance & Workshop Talk 2 11-03-2005 12:12 PM
