View Single Post
Old 02-28-2008   #2 (permalink)
daveforty
There are two fuel pipes from the petrol tap to junctions between the carbs. Inside those plastic junction pieces, where the fuel pipe attaches are small conical mesh filters, 'witches hats' as described by the mechanic at my local dealers, it is likely that they are clogged up. Unfortunately you will need to take the carbs off the engine to get to them. Probably worth getting some new petrol pipes as well, mine had perished and become brittle after a few years and split when I pulled them apart.
daveforty is online now   Reply With Quote
