I looked into this once. The caliper uses 6 separate pads(!) dinky little things from a Honda 50 or something.
You will almost certainly need a different master cylinder. The stock 11mm item is too small to begin with. A 1/2" or 14mm master cylinder would probably be a better match for the 6 pot.
