View Single Post
Old 01-15-2007   #3 (permalink)
TRI-AL
On 2007-01-14 09:55, GrandPaulZ wrote:
Slow fuel flow / low float level can contribute to that.
What happens is that at speed, you are actually running lean, then when you accelerate, you REALLY lean out.
So, this is not just "the nature of the beast"? Plugs burn nearly perfectly. Boyer ig. (although ran the SAME with points), New carbs. Perfect, smooth idle. It's not "serious" just "annoying". New fuel lines, cleaned tank/pet cocks...timing seems right on. :???: Any other ideas?
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline   Reply With Quote
