Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
View Single Post
Old 01-15-2006   #9 (permalink)
agro
On 2006-01-15 07:35, rodburner wrote:
Agro,I thought the Thrux module was frowned upon because of the different cam profile/timing curve? :???:
Should not matter timing advance might be a few deg different from the 790 module ie. less advance.
Probably need to check with Jojje for the differences in curves.
I will be fitting Bonney cams to my Thruxton soon, then the only difference to a 790 will be the Capacity, 865, and the Thruxton module
Cheers...............Agro
[ This message was edited by: agro on 2006-01-15 09:03 ]
"Whale Oil Beef Hooked"
agro is offline   Reply With Quote
