View Single Post
Old 06-22-2003   #21 (permalink)
Slinky
On 2003-06-21 15:05, tamalecks wrote:
Question 2) Where do I hook up the vacuum line on the Kawi fuel tap conversion???
You can take the vacuum from any one of the 3 vacuum connectors. There is one on each carb on the inlet side. They having blanking caps on them.
I am using the vacuum from two carbs hooked up with a tee piece. The other vacuum takeoff is running a Scottoiler.
